D15B Turbo Cam Gear Timing Help!
Hey all, i'm working on a D15b t3 turbo, cast mani, 3inch dp, 2+1/2 ' test pipe back, radiator, 4bar map sensor, walboro FP, 440cc injectors, fpr, p28 base mapped, currently running 7 lbs no problem, optimum AFR, ( not driven daily) Ive got a 5 bolt adjustable cam and woodruff key that id like to put on before i take it to the dyno if anyone has any input on what to set the timing to (approximation) it would be a huge help!
Thanks Alot!!!
Thanks Alot!!!
