uberdata & cam gear timing
Old Feb 26, 2006 | 10:17 PM
sk8shorty012's Avatar
Default uberdata & cam gear timing
Alright, just a quick question - Ive tried searching this before, but nothing really applicable to my setup comes up - I need some solid help.
Im running a d16y8 turbo tuned via wideband/uberdata running 7psi internally gated. Ive had an adjustable cam gear (AEM) on my car for a while (pre-turbo), but am wondering now that im boosted - what should it be set to? I know its possible to change the timing via uberdata, so ive been told to just leave the adj. cam gear at 0 and adjust the timing via uberdata. I really need someone to confirm that that's true...and if this was the case, then whats the point of the adj. cam gear? Wouldn't it be almost better to just put the OEM one back on?
Modified by sk8shorty012 at 11:43 PM 2/26/2006
Old Feb 27, 2006 | 05:05 AM
tegman85's Avatar
the point of adj. cam gear is to adjust the cam timing without haveing to buy a tunning unit, definitely better to use the unit though. the aem might be a fraction of a hair lighter than the stock one
Old Feb 27, 2006 | 08:14 AM
aight, so leave the adj. cam gear on, but set the timing to something or leave it at 0 and set the timing via uberdata?
Old Feb 27, 2006 | 12:02 PM
bump...anyone confirm this?
Old Mar 13, 2006 | 11:26 AM
tegman85's Avatar
thats what id do
Ef4doorwagon
13
May 17, 2014 06:09 PM
eg6BT
Oct 2, 2006 07:59 PM
sk8shorty012
Feb 27, 2006 06:36 PM
