Converting engine bay to full AN honda shop and k20 forum say one thing pirtek say an
#26
Re: Converting engine bay to full AN honda shop and k20 forum say one thing pirtek sa
If you're in an area where rust on cars is any problem at all, those 25 year old steel lines will be rusted underneath the car-- you should replace them all the way end to end. I can see why your mechanic is reluctant to touch them, they are likely to break and you'll blame him.
Really, splicing onto the stock lines at all is a sign of ghetto work. To do it right you want as few junctions as possible.
#27
#28
#29
Its true that you flare your tubing to 37 degree to convert to AN. And as someone mentioned, you could use the compression style AN fittings for your fuel feed and return, due to the fact that its relatively low pressure. I personally would do it right and flare them. Thats what I did on mine. Think about it, if youre going through the trouble of doing an AN brake tuck and doing all the 37 degree flares there, then when why not do it to the fuel lines too. But I would NEVER ....ever... ever... use any type of compression fittings on any part of the braking system. Why risk youre life to save 2 minutes. I done my brake tuck completely out of hard line and AN fittings, the actual brake hose, i went with off the shelf russel stainless lines. I spent $100 just in fittings.
I think having compression fittings in anything other than a toilet is bad. The **** tech made me question all 8 years of me doing hvac work and everything I learned about seals n ****.
#30
Compression fittings are used extensively in the naval nuclear and commercial nuclear industry in high pressure applications. Army Navy fittings are never used. Can anyone explain the fascination with Army Navy fittings among automotive DIY enthusiasts? Where does that come from?
#31
How are the Russel lines? Both of my rubber lines were damaged and I want to replace them. I got one from the local stealership for $50 months ago, then I noticed the passenger was damaged as well.
#32
Also the availability of AN bulk head fittings to pass lines in and out of the cockpit is great. Especially for the guys on here that do brake tucks. Because Ive yet to find bulkhead fittings for standard brake lines.
#33
Plus they come in neat colors.
#34
I like that they come in different colors. The AN flares are easy to understand if you are not like my dad and want to ask a million and one questions about them. They are a form of compression but coming from swedging hvac copper they are so much simpler than doing these bubble flares and ****.
#36
mdcruz4
07-25-2017 06:15 AM
Sloshy
11
11-02-2006 06:09 AM
JDMlyfestyle
10
05-18-2005 11:24 AM
