Code 30 after swap.
Old 07-31-2006, 05:46 PM
-[95cxhatch]-'s Avatar
Default Code 30 after swap.
Ok here is the scoop: A friend hooks me up with a good deal on a z6. All I have to do is pull the motor from his car and drop it into mine. The donor car is a 94 dx coupe that was converted to manual. My car is a bone stock 95 cx hatch. The swap goes perfect with no problems except for when I start up the cx engine in the dx coupe. Right away I am getting a code 30. There is a connector on the firewall next to the battery that is not plugged in to anything ( I'm assuming this is the automatic tranny connector) Is there something I can do disable this? any help is greatly appreciated.
Old 07-31-2006, 05:51 PM
THC07's Avatar
Default Re: Code 30 after swap. (-[95cxhatch]-)
get a chiped. the ecu can be converted.
Old 07-31-2006, 05:52 PM
THC07's Avatar
Default Re: Code 30 after swap. (THC1107)
remove RP17 and put a jumper at RP18
Old 07-31-2006, 06:46 PM
Even though this is a manual ecu I still have to chip it?
Old 07-31-2006, 07:21 PM
THC07's Avatar
Default Re: (-[95cxhatch]-)
if the ecu is converted to manual then no need for a chip.
Old 08-01-2006, 10:26 AM
the ecu was a manual to begin with
Old 08-01-2006, 06:10 PM
bump for some help...
Rifajnd
06-26-2016 11:17 AM
beastmodeej2
03-01-2013 05:23 AM
Kool305
12-27-2005 10:28 AM
rleroy
11
08-29-2005 10:07 AM
JDMCIV95
11-21-2002 06:30 PM
Quick Reply: Code 30 after swap.
