changing ecu from auto to manual
Old Nov 20, 2002 | 02:33 PM
JDMCIV95's Avatar
Default changing ecu from auto to manual
does anyone know which resistors to replace,and what size to use, in order to change an ecu from automatic to manual? i hve a p30 automatic ecu w/an manual tranny and i have a check code 19, something to do w/ an automatic lockup soleniod. help me!
Old Nov 20, 2002 | 04:21 PM
Simple's Avatar
Default Re: changing ecu from auto to manual (JDMCIV95)
hope this helps... at all?
i did get this off of an ECU chipping page... so it states that this chip is needed, but that chip is on the AT that the MT does not have
[Modified by Simple, 1:22 AM 11/21/2002]
Old Nov 20, 2002 | 05:21 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: changing ecu from auto to manual (Simple)
Yeah, I read about that little modification you can do to the chip, but if I remember correctly, you need to purchase something else as well to make it work.
Anyhow, yes I did that same swap and I have that same code coming up. I kept the same automatic LS ECU this entire time even with the turbo and whatnot. No problems whatsoever.
The code basically says "Something is wrong because I see the car moving, but the shift level position is in PARK." That's the only way possible because you have to have it in PARK to remove the key.
I just took out the bulb for the check engine light to pass emissions. If anything, just get a 5-speed ECU. LS ones should be cheap.
Old Nov 20, 2002 | 06:54 PM
b19coupe's Avatar
In my Hondata installation manual, it tells how to convert ECU's from automatic to manual. For the P28 ECU you remove resistor RP17 and install a jumper across RP18. It looks like the P30 is converted in the same manner. The manual is in Adobe Acrobat, and I don't know how to copy/paste it here.
[Modified by b19coupe, 3:57 AM 11/21/2002]
Old Nov 20, 2002 | 07:01 PM
Simple's Avatar
Default Re: changing ecu from auto to manual (b19coupe)
i think this might be the jumper you would need to cross
for the p28 ECU but not completely sure.
[Modified by Simple, 4:03 AM 11/21/2002]
Old Nov 20, 2002 | 08:20 PM
JDMCIV95's Avatar
where can i find the hondata instaltion manual?
Old Nov 20, 2002 | 09:20 PM
b19coupe's Avatar
I got mine with my Hondata software disc. (it's on the disc)
Old Nov 20, 2002 | 09:40 PM
b19coupe's Avatar
In the P28 ECU, there is a space where there is no chip labeled "27C256". When the ECU is chipped, that is where the chip goes.
This is one of my ECU's that have been modded. It is an automatic ECU that has been converted to a manual. The arrow points to where the resistors are. The circled space is where RP17 was. The "x" is next to my jumper at RP18.
Edit:kind of hard to see, but if you have your ECU close at hand,you will find what you are looking for.
[Modified by b19coupe, 6:42 AM 11/21/2002]
dr650's Avatar
New User
just get manual ecu.u will solve ur problem.(easy way)
Old Nov 20, 2002 | 10:08 PM
b19coupe's Avatar
Default Re: changing ecu from auto to manual (dr650)
Somebody posted this link in another thread.It is for the installation manual.
http://www.hondata.com/downloads/installation.pdf
That should help.
Old Nov 21, 2002 | 06:30 PM
JDMCIV95's Avatar
thanks to all
mattsthru
Aug 21, 2007 11:30 PM
rleroy
11
Aug 29, 2005 10:07 AM
MugenDC4
Jul 25, 2004 10:47 PM
JChops
Oct 9, 2003 06:53 PM
cbrman
Feb 11, 2002 08:51 PM
