check engine light on
Old Feb 24, 2009 | 10:28 PM
masijdm's Avatar
Default check engine light on
we just checked on my friends civic the CEL it shows
45 Fuel system too rich or lean any ideas? to fix that
Old Feb 24, 2009 | 10:32 PM
EK9r!der's Avatar
Default Re: check engine light on
check your spark plugs, pull one out and post a pic.
Old Feb 25, 2009 | 03:41 AM
934door's Avatar
i would check for vacuum leaks , that would cause a rich condition. but a clogged fuel filter would cause a lean condition and the fuel pressure regulator could cause rich/lean conditions..
Old Feb 25, 2009 | 05:17 AM
Former User's Avatar
Take the car to AutoZone. They will pull the code with a scan tool, which will tell you whether the code is for lean versus rich. This will help with troubleshooting.
Old Feb 25, 2009 | 11:19 AM
masijdm's Avatar
Old Feb 25, 2009 | 11:27 AM
sirt_eg's Avatar
looks like carbon build up. Check your timing, and any vacuum leaks.
Old Feb 25, 2009 | 11:28 AM
masijdm's Avatar
should i keep those SPARK plugs or change them
Old Feb 25, 2009 | 11:39 AM
sirt_eg's Avatar
change them, but find out what cause them first, cause if it happens to those it will happen again to the new ones.
Old Feb 25, 2009 | 01:47 PM
EK9r!der's Avatar
yeah change them, also check your timing and for any vacuum leaks.
Old Feb 25, 2009 | 06:06 PM
masijdm's Avatar
yeah when he revs it the black smoke comes out with water its a 99 si
Old Feb 26, 2009 | 01:10 AM
masijdm's Avatar
[URL=http://s533.photobucket.com/albums/ee335/jdmlsintegra/?action=view&current=02-25-09_1609.flv /URL]
is that the right code?
Old Feb 26, 2009 | 04:07 AM
That's code 65 for the secondary O2 sensor.
B20inDCinLBC
Oct 10, 2008 10:44 PM
weirdone86
Sep 14, 2006 07:35 AM
Mik3
Jan 26, 2006 06:35 AM
HONDA RR
Nov 7, 2004 09:12 AM
HiGhCaM
Nov 26, 2001 05:56 PM
