battery light problem is stressing me out..please help
Old 12-07-2006, 02:49 PM
PinoyCivic's Avatar
Default battery light problem is stressing me out..please help
ok so my battery light came on, i checked the batt. and the alternator, the alternator is good, and replaced the batt. but i still have the problem of the battery not charging properly while its running. but everything is fine. its driving me crazy! i think its a bad connection somewhere but i cant seem to find it. anyone ever had this problem? thanks
-PinoyCivic
Old 12-07-2006, 03:19 PM
JSPECSIR's Avatar
Default Re: battery light problem is stressing me out..please help (PinoyCivic)
make sure all your plugs are in good in the alt. also check the 100 amp fuse under the hood.
Old 12-08-2006, 09:24 AM
PinoyCivic's Avatar
aight ill go check those out, plus ima go get some new connectors for the batt. this **** is really making me crazy.
-PinoyCivic
Old 12-08-2006, 10:19 AM
PinoyCivic's Avatar
Default Re: battery light problem is stressing me out..please help (JSPECSIR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECSIR &raquo;</TD></TR><TR><TD CLASS="quote">make sure all your plugs are in good in the alt. also check the 100 amp fuse under the hood.</TD></TR></TABLE>
ok well i checked the plugs, they seem fine, nice and snug, but i cant find the 100 amp fuse you mentioned, it should be in the fuse box right? (dont hate)
-PinoyCivic
Old 12-08-2006, 10:27 AM
hatchi's Avatar
check all your fuses especially under the dash
Old 12-08-2006, 10:34 AM
EE_Chris's Avatar
The battery light is controlled by the alternator. How do you know the alternator is good? Any CEL's? What's the setup?
Old 12-08-2006, 11:47 AM
PinoyCivic's Avatar
Default Re: battery light problem is stressing me out..please help (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">The battery light is controlled by the alternator. How do you know the alternator is good? Any CEL's? What's the setup?</TD></TR></TABLE>
i had the alternator checked, its a stock 92 civic lx
-Pinoycivic
Old 12-08-2006, 12:39 PM
digitalcongo's Avatar
i had an alternator check positive at autozone hours before it died...
Old 12-08-2006, 08:51 PM
PinoyCivic's Avatar
Default Re: battery light problem is stressing me out..please help (digitalcongo)
yea i guess thats wuts up, ima just get another one, hopefully that will be it. thanks
-PinoyCivic
Old 12-09-2006, 03:51 AM
tietze's Avatar
You can download a manual for your car here...
http://www.hondahookup.com/manuals/
In the electrical section there is a great troubleshoooting flowchart for checking the 1. battery
2. light circuit
3. alternator/regulator.
The problem is probably a fuse, voltage regulator,(part of the alternator) or alternator if you have already replaced the battery.
Old 12-09-2006, 04:51 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digitalcongo &raquo;</TD></TR><TR><TD CLASS="quote">i had an alternator check positive at autozone hours before it died...
Exactly. Autozone testing of Honda alternators has produced more than it's fair share of false positives. And using those alternators from there - good luck. It seems like a 1 in 3 shot of getting a decent one from places like Autozone.
Old 12-09-2006, 05:35 AM
AnotherEJ's Avatar
Exactly. Autozone testing of Honda alternators has produced more than it's fair share of false positives. And using those alternators from there - good luck. It seems like a 1 in 3 shot of getting a decent one from places like Autozone.</TD></TR></TABLE>
Yeah I had to replace mine on my old Wrangler and the first one we bought didn't even work Second one work good for the rest of the time I had it at least.
Old 12-10-2006, 02:26 PM
1990crx's Avatar
i've had my alternator checked and i was told it was fine, then when i changed it out, the car was fixed. but the one method that has NEVER failed me has been to turn the car ON and disconnect the negative battery cable. if the car stays on, you're golden. if it turns off, the alternator is bad. good luck.
alperx
11-27-2012 05:47 AM
Jakeryanconklin
10-08-2012 09:28 AM
sirtef9
Honda Civic (2001 - 2005)
14
01-15-2010 10:37 AM
90goldhatch
24
02-28-2008 06:57 PM
rasta420
11-06-2002 08:41 PM
Quick Reply: battery light problem is stressing me out..please help
