98 EX manual tranny problem
I'm getting this annoying noise from the tranny. At first I thought it was the TOB so I had the clutch and TOB changed plus a new flywheel , but after the replacement the sound still exists.
Here is the description: The car is idling , press in the clutch pedal and it goes away. Let go of it and its back. I'll accelerate in 1st at times it will disappear for a sec and then come back. Even when I downshift to slow down you know how the engine is supposed to sound , well its a lot louder. Or if I slow with the clutch pedal in shifting it through the gears I hear some what of a ticking sound.
So what do you guys think it is? A bad bearing or something? Should I change out my tranny?
TIA
TIA
Risky Business
Re: 98 EX manual tranny problem (CPL)
https://honda-tech.com/zerothread?id=746865
https://honda-tech.com/zerothread?id=682329
https://honda-tech.com/zerothread?id=627341
https://honda-tech.com/zerothread?id=729382
https://honda-tech.com/zerothread?id=649758
https://honda-tech.com/zerothread?id=590820
https://honda-tech.com/zerothread?id=494094
https://honda-tech.com/zerothread?id=721260
Next time search please...there are 10 threads about this a day...but i'll cut you a break...
Input Shaft Bearing
Symptoms: https://honda-tech.com/zerothread?id=590820
Replacement: https://honda-tech.com/zerothread?id=596873
A pic:
What happens if you don't fix it soon:
The ISB will get chewed up and thrown all over the tranny...destroying it and locking it up. Tom (B18C5-EH2) said he drove around for a few months on a bad one and he was locked out of gears (destroyed tranny).
Input Shaft Bearing
A pic:
Re: 98 EX manual tranny problem (GRAVEDIGGER)
Cool!!! Thanks guys!
Sorry that I did'nt search but I didnt have time to since I was at work. Its the only time I can use the internet right now real quick.
Thanks again!
Thanks again!
Pslappa
09-12-2004 03:42 PM
