94 Civic - b16 has VTEC bog
Old 09-02-2011, 01:00 PM
njw202's Avatar
Default 94 Civic - b16 has VTEC bog
i have a b16a in a 94 civic coupe. i started having problems with my motor and i cant seem to find out what is really is. when my car goes to go in vtec it bogs and i loose my power. i changed my solenoid and that didn't fix the problem. it also seems like i don't have all my power as im accelerating while driving. the rpms jump a little at ideal. a few of my friends told me to check my ecu so i did that and its fine.
Old 09-02-2011, 05:24 PM
morbius18's Avatar
Default Re: b16 problems
Mine was doing the same thing and I changed the plugs and wires. It turned out that one of my wire was shorting out. It would occasionally miss and start bogging at higher rpms.
Old 09-03-2011, 04:26 AM
njw202's Avatar
what kinda plug wires should i get. im working on building a head and putting skunk2 cams and a skunk2 intake.
Old 09-03-2011, 04:31 AM
Technical Hero
HondaPartsHero's Avatar
Honda OEM
Old 09-03-2011, 04:41 AM
njw202's Avatar
im looking for cams now anyone know where i can pick up a set thats not 600 dollars.
Old 09-03-2011, 05:42 AM
njw202's Avatar
ok i changer my plugs plug wired and fuel filter and my car still wont go in vtec it bogs when my vtec should kick in. and its sounds like the power is there but my acceleration is shitty. i still cant find out what it is.
Old 09-03-2011, 05:43 AM
njw202's Avatar
ok i changer my plugs plug wired and fuel filter and my car still wont go in vtec it bogs when my vtec should kick in. and its sounds like the power is there but my acceleration is shitty. i still cant find out what it is. if you want i can make a video n show you what its doing.
Old 09-03-2011, 07:59 AM
njw202's Avatar
Default Re: 94 Civic - b16 has VTEC bog
iv also noticed i dont have any power when i try to clime a hill.
Old 09-03-2011, 10:14 AM
Rusty22's Avatar
does it shutter? when you hit the gas?
Old 09-03-2011, 11:39 AM
njw202's Avatar
it shudders a little when i start it and some times stalls out.
Old 09-03-2011, 11:41 AM
njw202's Avatar
im thinking is had something to do with the vacuum but im not sure.
Old 09-03-2011, 12:04 PM
morbius18's Avatar
How does it idle when you are sitting still?
Old 09-03-2011, 01:13 PM
Rusty22's Avatar
fuel pump/injector? bad?
Old 09-03-2011, 03:22 PM
njw202's Avatar
it starts kinda funny and the rpms bounce a little but when its warmed up it sounds fine sitting there. its only in my higher rpms that im having problems when driving. when the vtec goes to kick in it makes a nasty bog sound and im not getting all the power out of my motor any more. starting off its great untill my rpms are high or i try to clime a hill. all 4 cylinders are good i have good compression good spark. new plugs and wires new fuel filter. my injectors are all good.
Old 09-03-2011, 04:22 PM
njw202's Avatar
it bogs at 6k and wont go any farther.
Old 09-03-2011, 04:45 PM
njw202's Avatar
check this youtube video out. if you listen right be for i shift around 6k cause it wont go any higher you can hear it. it sounds like ***.
<iframe width="420" height="345" src="http://www.youtube.com/embed/hLhBHndsYlw" frameborder="0" allowfullscreen></iframe>
Old 09-03-2011, 04:46 PM
njw202's Avatar
http://www.youtube.com/watch?v=hLhBHndsYlw
Old 12-07-2011, 02:51 PM
junior h.m's Avatar
Did you find a repair solution for this? Mine is doing this.
Old 03-14-2012, 05:28 PM
njw202's Avatar
New ecu plugs timing belt and plug wires and it went away.
Old 04-28-2012, 01:38 PM
njw202's Avatar
also the piece under the throttle body i adjusted. im not sure what the name of it is but it made a big difference.
Old 04-28-2012, 02:20 PM
vyrus's Avatar
Subscribed since i face the same issue!
Old 05-05-2012, 06:38 AM
njw202's Avatar
It's the Throttle Position Sensor under the throttle body. Be careful taking the. Bolts off cause sometimes they may brake.
Smurf accord
09-21-2013 04:31 AM
EJ1 JDM Boostin
01-02-2010 03:44 PM
lowtegsr
02-11-2008 04:32 PM
thegamettt
58
10-17-2007 01:30 PM
that_guy
10-03-2003 01:30 AM
Quick Reply: 94 Civic - b16 has VTEC bog
