92 Civic w/gsr swap a/c question
I have a 92 Civic Ex and installed a 94 GSR swap. Trying to figure out which way to go with the a/c lines. Obviously the stock lines for the Civic won't work but tried some from a 94 Civic and a quick test fit this morning before work it didn't look like they are going to work either.
My question is what will need to be used so the lines will work on the 94 GSR compressor? Which lines will I need to swap out and from what vehicle?
Re: 92 Civic w/gsr swap a/c question
wrong^^^keep the stock single cam compressor and get a crv or del sol ac bracket..
92 civics have r12 ac lines and are completely different ac setup of that of a 94 up civic or integra.
to use that gsr compressor in your car is alot more work because you would need to change all the lines from the ac compressor back to the firewall including mounting up a integra condensor and change the ac evaporator inside the cabin...
So a 1st gen CRV a/c bracket and a 92-93 Civic a/c compressor? The Civic compressor bolts up to the crv bracket fine? Civic compressor pulley the same for using the same belt from the GSR compressor or will the pulley need to be changed out?
Just get a 92-93 compressor and use the pulley that comes on it. Then you have to get a del Sol belt for the bracket that you will be using to mount it to. Or CRV.
e46joe
09-25-2011 06:09 AM
