00 si gear grinding?
Old 02-01-2006, 02:16 PM
mhart's Avatar
Default 00 si gear grinding?
i have an 00 si and when i shift to 5th gear it grinds alittle going in. do i need to adjust something, or do i need a new 5th gear? thanks
Old 02-01-2006, 05:49 PM
OogalyDoogaly's Avatar
Default Re: 00 si gear grinding? (mhart)
Try changing your clutch fluid
Old 02-01-2006, 06:30 PM
Sir_Wallace's Avatar
Honda's Have super cheap trany's. People bring them to me all the time with bad syncros and striped gears. There not worth fixing. You best bet is to change your trans fluid with something heavy, like LSD oil. You can get it a most auto parts stores. Your car takes 2 1/2 quarts.
Old 02-01-2006, 10:30 PM
Swapped_EG's Avatar
Thats true about the tranny being cheap, but a lot of the time the problem is the blocking ring (or syncro ring). And that isn;t too expensive to fix, as long as you catch it before it starts to tear up the gears or syncro itself. And adding a heavier oil won't do much, its kinda like a bandaid it works OK for a while then your back to square 1. Only worse than when you started.
Old 02-02-2006, 08:29 AM
whitelightning's Avatar
Default Re: 00 si gear grinding? (OogalyDoogaly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OogalyDoogaly &raquo;</TD></TR><TR><TD CLASS="quote">Try changing your clutch fluid</TD></TR></TABLE>
tranny fluid
Old 02-02-2006, 08:44 AM
Banned
CardDealer's Avatar
Modified by CardDealer at 3:01 PM 11/16/2006
Old 02-03-2006, 11:19 AM
mhart's Avatar
Default Re: 00 si gear grinding? (schlit)
thanks everyone.
crazyness462
01-20-2008 01:44 PM
fyr3
04-25-2005 12:27 AM
JDM00SI
02-01-2005 05:09 AM
undercoversi
01-17-2005 03:07 PM
Spudddy
06-14-2003 04:50 PM
Quick Reply: 00 si gear grinding?
