buying a used accord?
Hi all. I'm new here. I'm looking into buying a used, 02-05, accord. More than likely automatic. It'll have over a hundred k on it. Would love some advice about what to look for. What are the biggest issues with these? Thank you so much for your time.
Jason
Jason
Re: buying a used accord?
With an auto you'd want to know about some trans service being done before = drain and fill of the fluid especially if getting one with over 100K.
Next, if a 4 cyl, pretty good records of oil changes and no major signs of leaks. The 4 cyl have a timing chain that will wear if the oil is low or not serviced on a scheduled interval.
If it is a 6 cyl, then you want to know when the "timing belt job" was last done. The 6 cyl have a timing belt that is due ~ every 100K or 7 years.
rileyparrish
03-04-2010 09:00 PM
Two400
01-22-2008 04:10 PM
