2007 accord sedan 2.4l
Re: 2007 accord sedan 2.4l
Again, the four cyl (Canada I know does - pretty sure UK as well, I see you are using km not miles) have a chain and only will need to be replaced if and when it stretches too much - and again, regular/quality oil changes - level checks will help extend the time.
Although the 4 cylinder has a timing chain that doesn't require replacement under normal circumstances, there is still a drive belt that should be changed at recommended service intervals.
Re: 2007 Accord Ssedan 2.4L 24valve, DOHC iVtec
Thanks. Actually, this is a USA car. Registered in miles. I do regular oil changes every 10,000m with full synthetic oil. I don't know if it has a chain or belt. But, drive belt shold be replaced at 60,000miles?
For the drive belt, check the condition of the drive belt (i.e., look at the auto-tensioner gauge position if it is within range (there is a pointer and gauge range on the auto-tensioner), inspect belt for obvious damage; a few cracks (rib side of belt) is not a big concern, only if a lot of cracking or chunks gone then it is a concern). Replace belt if gauge position not within range, or belt damage. Otherwise, under normal conditions, drive belt should be good for at least 105,000 miles. I like to change it a little before or at about 105,000 miles.
cavaliertx
12-13-2016 09:02 AM
Two400
01-22-2008 04:10 PM
04accord94civic
04-27-2005 04:53 AM
