91cb7 with swap will idle but wont rev up
Old Jul 23, 2011 | 08:16 PM
djlooneyca's Avatar
Default 91cb7 with swap will idle but wont rev up
ok i have a 91 accord with a h23a vtec swap that has been running fine for awhile in tell today i was driving it and pulled over to talk to a friend and when i started it back up it ran rough and almost didnt make it home and when i got it home
it will idle and run but when i pull the gas pedal it stubles and bogs but if i slowly press the pedal it will rev up but if i try to floor it it will bog and stuble
and if i work the the pedal it kinda rev up it has no check egine codes and i
have check just about every thing i can think of
any i deals will help
Old Jul 23, 2011 | 09:41 PM
nus_dogg's Avatar
Default Re: 91cb7 with swap will idle but wont rev up
Make sure that the injectors are clicking by listening it through a long screwdriver. If one is inoperative, the engine will idle rough. Also, check that all spark plug wires are not open meaning no sparking when you spray mist of water on the spark plug wires.
Old Jul 23, 2011 | 09:51 PM
sauls1's Avatar
check ur tps... i had one go out on a ls integra the little spring broke in it and it did the same thing
Old Jul 24, 2011 | 05:33 AM
djlooneyca's Avatar
will check in a little bit thanks
Old Jul 24, 2011 | 11:55 AM
djlooneyca's Avatar
well i did some test and it turns out that i only have 10psi fuel pressure
so iam going to start with all the grounds and then the filter and then the pump that was just replaced 6 months ago
Domani99
Sep 22, 2012 08:24 PM
wagonator
Oct 18, 2011 09:31 PM
pnoi_boi68
Apr 15, 2010 08:21 AM
bads2k
Jul 24, 2009 07:37 PM
ck123
Oct 17, 2006 10:46 AM
