rough idle
Old Oct 17, 2011 | 08:05 PM
wagonator's Avatar
Default rough idle
93 accord has rough idle but runs just fine throughout the rpm range
the check engine light comes on after it warms up and it has 246,000 miles.
Old Oct 17, 2011 | 10:58 PM
nus_dogg's Avatar
Default Re: rough idle
Check for vacuum leak. Also inspect your plugs, cap, rotors, and plug wires.
Old Oct 18, 2011 | 07:27 PM
P_Adams's Avatar
Check your codes first. The ECM is trying to tell you something. I've had this happen when a customer's Top Dead Center sensor decided to take a sabatical.
P
Old Oct 18, 2011 | 09:22 PM
jdmcertified909's Avatar
Yup yup check codes firsrlt
Old Oct 18, 2011 | 09:26 PM
Yup yup check codes first. Theres a plug behind the passenger kick panel. Its blue. Jump it with a paper clip. Piece of wire etc. Then turn key to II and see the check engine flash. Read the cose then post it here so we can futher assist you
Old Oct 18, 2011 | 09:31 PM
Dioxine's Avatar
Does it idle fine until the light comes on or rough idle as soon as you start?
brant
Mar 29, 2011 06:43 PM
pnoi_boi68
Apr 15, 2010 08:21 AM
dystro
Jan 30, 2006 11:22 AM
sr20seth
May 31, 2003 08:24 AM
