Teal Integras
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlphaQup »</TD></TR><TR><TD CLASS="quote">
Thanks for lookin out Erik.
I'm cool though. I'll just keep an eye out for any noticeable signs of stress on the subframe from time to time.
**EDIT**
I forgot to ask you... what type of cars were your friends driving, who had the ripped out subframes from using the BSQ kits?
Modified by AlphaQup at 2:11 PM 9/15/2008</TD></TR></TABLE>
LS's and GSR's using the 22mm R bar with varying suspensions from stock ITR shocks and springs to things like Koni Yellows with rates as high as 400-450 lb/in.
I'm cool though. I'll just keep an eye out for any noticeable signs of stress on the subframe from time to time. **EDIT**
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by A’s 94 GSR »</TD></TR><TR><TD CLASS="quote">I think I'm leaking coolant.
where? why?
</TD></TR></TABLE>where? why?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik95LS »</TD></TR><TR><TD CLASS="quote">
where? why?</TD></TR></TABLE>
Here's what I posted on anothe forum..
After a good 20-30 minute drive today from school, I parked my gsr at my house. After I parked her, I went around to the passenger side to grab my books and camera gear out of my car. After that I noticed there was steam coming from the hood, next to my windshield.. it had a white color to it. Popped the hood and noticed there was some liquid sprayed around where my throttle body is, it sprewed on my intake, to the battery, top of hood a bit, etc. I then moved the gsr from the spot I parked her in and noticed there was a puddle on the ground.
I touched it and it felt a little oily, but didn't realy smell like oil... had a yellow tint to it too. Next I moved it back to the original spot I parked her and noticed another spot (she only sat like a minute in the second spot).. was just like the first puddle. I then started her up and poppped the hood. Everything looked fine, aside from the liquid from before. revved the engine a little, didnt notice anything spraying around. Then I checked my oil and everything was fine. Could I have a leaky hose for my coolant.. or am I not even leaking coolant?
nobody has responded either.. oh and no, i didnt get undernieth the car to check it out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik95LS »</TD></TR><TR><TD CLASS="quote">does it smell kind of like maple syrup?</TD></TR></TABLE> I'm not sure, I'd go back outside to smell it, but its dark out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gringotegra »</TD></TR><TR><TD CLASS="quote">Sounds like coolent to me... good coolent/antifreeze feels oily.... </TD></TR></TABLE>
Wow thanks for the quick responses guys. Yeah, I think I might have a leaky hose.
no problem....check around your throttle body and manifold..ive had a few leaks around there before...
</TD></TR></TABLE>no problem....check around your throttle body and manifold..ive had a few leaks around there before...
it looks like it is right around the throttle body because there is some of the liquid on top of it.
should i determine what the problem is and then take it to a garage or is it an easy fix?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by A’s 94 GSR »</TD></TR><TR><TD CLASS="quote">it looks like it is right around the throttle body because there is some of the liquid on top of it.
should i determine what the problem is and then take it to a garage or is it an easy fix?</TD></TR></TABLE>
just depends on what the problem is. A leak like that will be easy to find and if it's in a hose (most likely) then that's a simple 10 minute, $10 fix. Just need to make sure it's really coolant and find the leak.
Modified by Erik95LS at 8:53 PM 9/18/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gringotegra »</TD></TR><TR><TD CLASS="quote">TEAL in the 11.7's!!
gringo dude... keep it up man. That's one fast BG-33P teg ya got there. I'm proud of you.
thanks man!! im trying!
</TD></TR></TABLE>thanks man!! im trying!
Modified by Erik95LS at 8:53 PM 9/18/2008</TD></TR></TABLE>
i've got a coolant problem too. after we put a plastic intaake manifold gasket on it started leaking...but it only leaks enough to smell it. it never puddles or anything.
not that anyone's nterested, but i started saving my pennies for my rust problem. i'm tired of my car looking like sh*t.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik95LS »</TD></TR><TR><TD CLASS="quote"> just depends on what the problem is.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gringotegra »</TD></TR><TR><TD CLASS="quote">figure out what the problem is then let us know.</TD></TR></TABLE> I'll let you know when I get the chance to jack her up and look around. School's owning me right now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tslaughter05 »</TD></TR><TR><TD CLASS="quote">dumb question but did u check ur coolant? </TD></TR></TABLE> yeah, but what does the coolant level have to do with the leak? I mean, I know I'm leaking.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gringotegra »</TD></TR><TR><TD CLASS="quote">TEAL in the 11.7's!! </TD></TR></TABLE> Nice man, she's quick.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EpicKills »</TD></TR><TR><TD CLASS="quote">On the way back from the club later at night I pulled up to a gas station and white smoke started coming from under my hood. My coolant was boiling over. Good Luck with your gsr.</TD></TR></TABLE> Boiling over as in, too much coolant? What did you do to fix it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ONELIFEMOTORSPORTS »</TD></TR><TR><TD CLASS="quote">I think coolant smells like old dirty CELERY</TD></TR></TABLE> So maple syrup or celery? lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA6righthand »</TD></TR><TR><TD CLASS="quote">not that anyone's nterested, but i started saving my pennies for my rust problem. i'm tired of my car looking like sh*t.</TD></TR></TABLE> When do you plan on getting it taken care of, winter time?
TO all with leaks by a pressure tester or rig something up!! You do not want a pocket of air in the system.. one can be had for around 40$$ and you will have it forever!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ONELIFEMOTORSPORTS »</TD></TR><TR><TD CLASS="quote">TO all with leaks by a pressure tester or rig something up!! You do not want a pocket of air in the system.. one can be had for around 40$$ and you will have it forever! </TD></TR></TABLE>
Something like this?
no that is like a glorified boost gauge!! that i believe is for detecting map to see if you have a vacumn leak, also will tell you your fuel pressure!
You need something like this, a little more then i thought http://www.thetoolwarehouse.ne....html
Also if you get one you will have better results putting the tester on the rad then let it run till the t-stat opens, so your not forcing it through the jiggle pins of the t-stat.SHUT CAR OFF. Then pump till the gauge says what psi is on cap i think 17psi *just dont go crazy over* then i watch the gauge to see if it falls in pressure if does PUMP AND SEARCH FOR LEAK !!!
SOME updates with my car.
going down to Venus auto (where i bought my front end) on tuesday to pick up a ITR lip.
tomarrow i am ordering some jdm power folding mirrors.
also tomarrow i am picking up a fog light wiring kit and buying a OEM honda fog light switch so i can get my OEM fogs working.
next saturday my body work on the whole car will get finished, and two weeks from today the car should be painted.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by A’s 94 GSR »</TD></TR><TR><TD CLASS="quote">When do you plan on getting it taken care of, winter time?</TD></TR></TABLE>
hopefully. i'm gonna try to get it done before spring. i think i'm getting the whole quarter panels...i don't trust anybody to match the body lines and i have tiny rust spots behind the moldings and plenty of dents.. along with the 1/4's, i'm gonna get my rear bumper repainted. it looks like hell. plus we took off the ghey option2 sticker and it took clear coat with.
my hatch my need replaced to. where the spoiler would go, there's a sh*t ton of tiny dents where most of you put your hand to close the hatch. theres just too many to fix. not to mention the clear coat isn't shinny any more
for garage spots
for parking outside
for garage spots
for parking outside
