DA Integra's Only
Old Oct 5, 2007 | 10:53 AM
  #19426
g2_teg_'s Avatar
Default Re: (Morasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">Before I take my ITR shift boot out of the bag (have had it for ages) will it go right into my DA?
It looks like it will but haven't put too much effort into it to be honest. I always think about it at work and not at home</TD></TR></TABLE>
u have to switch the boot to the ring from your original boot. then it'll work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Morasso &raquo;</TD></TR><TR><TD CLASS="quote">So, my cars problems just got worse.
I got it started at a resturant, started driving out, and then my idle dipped REAL low. I pressed the gas and it died out.
Now it wont start, it'll crank, and its getting a spark, but it wont fire up.
Any ideas? I'm gonna go back tomorrow and shoot some starting fluid in the throttle body and see if that works. But any other ideas?</TD></TR></TABLE>
do an engine swap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohctor_B &raquo;</TD></TR><TR><TD CLASS="quote">
U still haven't tried a cap and rotor? I would try that, its not too expensive. Like I said before, I'm having similar problems but not as bad as yours. But cap and rotor are what I'm gonna try</TD></TR></TABLE>
heh....
Old Oct 5, 2007 | 11:02 AM
  #19427
Thrashin's Avatar
Default Re: (FBP_EM1R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FBP_EM1R &raquo;</TD></TR><TR><TD CLASS="quote">someone in the northeast sell me their DA. i have $8000 to spend!</TD></TR></TABLE>
****, I'll deliver you mine for 8k!
Old Oct 5, 2007 | 11:13 AM
  #19428
DA9_DAD's Avatar
Could that be it even if i'm still getting a spark?
You may just have to replace the Dizzy. thats what happened to me when I was driving home a few months ago. Also, if that doesn't fix the problem look into the fuel pump you may have dirty injectors or a fuel pick up problem. consider replacing the fuel filter. Or if you washed the car and water gets into the chambers where the spark plugs are, just simply remove the plugs and crank it over a few time to suck the h2o out...it doesn't harm anything or timing. then remove the dizzy cap-cover and wipe down the rotor and cap and replace. hmmmm what else what else. maybe check the ecu for CEL codes.
Old Oct 5, 2007 | 11:26 AM
  #19429
Morasso's Avatar
Default Re: (g2_teg_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2_teg_ &raquo;</TD></TR><TR><TD CLASS="quote">
do an engine swap.
heh....</TD></TR></TABLE>
I'm trying to get a bike first...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA9_DAD &raquo;</TD></TR><TR><TD CLASS="quote">
You may just have to replace the Dizzy. thats what happened to me when I was driving home a few months ago. Also, if that doesn't fix the problem look into the fuel pump you may have dirty injectors or a fuel pick up problem. consider replacing the fuel filter. Or if you washed the car and water gets into the chambers where the spark plugs are, just simply remove the plugs and crank it over a few time to suck the h2o out...it doesn't harm anything or timing. then remove the dizzy cap-cover and wipe down the rotor and cap and replace. hmmmm what else what else. maybe check the ecu for CEL codes. </TD></TR></TABLE>
I'm gonna try swapping dizzys tonight... ECU isnt throwing up codes, and fuel pump was replaced less than a year ago. Could be the injectors though.
Old Oct 5, 2007 | 11:29 AM
  #19430
BoostinEJ1's Avatar
Default Re: (Thrashin)
if it has less then 80k then its a deal haha
Old Oct 5, 2007 | 01:00 PM
  #19431
jdmkid8383's Avatar
Default Re: HELP .. (kiDchaos)
Yea Its a RHD conversion my first one It took me 3 days to do it It turned out well. with confidence you can do anything..Thanks for all the advice from Panda Hatch he has a orange RHD DA with a K20 swap hes from the OHIO AREA..
Old Oct 5, 2007 | 01:25 PM
  #19432
thelate1's Avatar
I'm gonna try swapping dizzys tonight... ECU isnt throwing up codes, and fuel pump was replaced less than a year ago. Could be the injectors though.</TD></TR></TABLE>
fuel filter maybe????
Old Oct 5, 2007 | 01:27 PM
  #19433
EFSedan#6's Avatar
Default Re: ENDUR (J's 94 Accord)
I like these wheels.
Old Oct 5, 2007 | 01:38 PM
  #19434
b6t's Avatar
b6t
https://honda-tech.com/zerothread?id=2098974
Old Oct 5, 2007 | 03:39 PM
  #19435
ntegrals's Avatar
* B A N N E D *
Old Oct 5, 2007 | 04:17 PM
  #19436
URBAN4's Avatar
Default Re: (ntegrals)
^ Clean
This one turned out weird, looks like a chop
I LOVE these tyres!! High speed turns are awesome, tight corners even better
Old Oct 5, 2007 | 05:52 PM
  #19437
da9wonder's Avatar
Default Re: (URBAN4)
heh?
Old Oct 5, 2007 | 07:53 PM
  #19438
g2_teg_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by URBAN4 &raquo;</TD></TR><TR><TD CLASS="quote">I LOVE these tyres!! High speed turns are awesome, tight corners even better </TD></TR></TABLE>
what tires are those?
Old Oct 6, 2007 | 01:30 AM
  #19439
URBAN4's Avatar
Bridgestone Potenza Adrenalin RE001.
Old Oct 6, 2007 | 03:30 AM
  #19440
king-of-the-hill's Avatar
Old Oct 6, 2007 | 04:28 AM
  #19441
Dateggy21's Avatar
very nice
Old Oct 6, 2007 | 05:37 AM
  #19442
allstar scuba's Avatar
wow
Old Oct 6, 2007 | 05:45 AM
  #19443
.Hatches.'s Avatar
expletive i want a DA. i know one day i'll drive down to cities that don't have snow and buy a clean DA.
Old Oct 6, 2007 | 08:11 AM
  #19444
hb420's Avatar
Default Re: (.Hatches.)
Very nice da king of the hill.
Old Oct 6, 2007 | 01:54 PM
  #19445
mugenDAxsi's Avatar
Default Re: (king-of-the-hill)
did you switch the odometer or do holland DA's come like that???
Old Oct 6, 2007 | 03:19 PM
  #19446
Coke in a Can's Avatar
I do what I want
someone buy my jdm DA window visors.
http://www.hondamarketplace.co...14551
Old Oct 6, 2007 | 03:21 PM
  #19447
g2_teg_'s Avatar
Default Re: (Coke in a Can)
hey guys, gotta question. i was reading about stock sway bar sizes and i came across this:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xx1NT3G-R4xx &raquo;</TD></TR><TR><TD CLASS="quote">Stock sway bar specs
Integra model - Front / Rear diameter (mm)
86-89 All Models - 17.0 / 17.0
90-93 All Coupes - 23.0 / 14.7
90-93 All Sedans - 23.0 / 15.9
94-99 RS/LS/GS/SE Coupe - 22.1 / 12.9
94-99 RS/LS/GS/SE Sedan - 22.1 / 14.0
94-01 GS-R - 24.0 / 14.0
97-01 Type R - 24.0 / 22.0
00-01 LS/GS Coupe - 24.0 / 12.9
00-01 LS/GS Sedan - 24.0 / 14.0</TD></TR></TABLE>
is that confirmed that 90-93 integra sedans have larger rear sway bars then the hatchbacks?
Old Oct 6, 2007 | 07:30 PM
  #19448
EJ_ALLMOTA's Avatar
Just 2 of my homie Boosted_Nonv's DA..
Old Oct 6, 2007 | 07:43 PM
  #19449
jdmkid8383's Avatar
Default Re: (mugenDAxsi)
A couple shot on the freeway..
Old Oct 6, 2007 | 07:59 PM
  #19450
mike9571's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kiDchaos &raquo;</TD></TR><TR><TD CLASS="quote">
is that a RHD conversion?</TD></TR></TABLE>
A hacked one at that
