DA Integra's Only
Old Aug 29, 2006 | 11:35 PM
  #9526
Nevets's Avatar
Default Re: first car (mugenDA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenDA &raquo;</TD></TR><TR><TD CLASS="quote">
sportmax </TD></TR></TABLE>
My thoughts exactly.
Old Aug 29, 2006 | 11:38 PM
  #9527
mugenDA's Avatar
Default Re: first car (Nevets)
lol. why hate. my car. my decision.
Old Aug 29, 2006 | 11:39 PM
  #9528
Nevets's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenDA &raquo;</TD></TR><TR><TD CLASS="quote"> my car. my decision.</TD></TR></TABLE>
correct. But, i like your car, just not the wheels.
Old Aug 29, 2006 | 11:42 PM
  #9529
mugenDA's Avatar
oh well. I was expecting people to hate.
Old Aug 29, 2006 | 11:57 PM
  #9530
kanjia's Avatar
Sorry to hate, but I'd rather ride on racing rims, like say... volks. Finally got a pic for you all to see. check the rest at my cardomain, hahaha.
Old Aug 30, 2006 | 12:03 AM
  #9531
t . b o z's Avatar
looks like a skate board. Get some over fenders, and you might have a nice ride.
Old Aug 30, 2006 | 12:14 AM
  #9532
kanjia's Avatar
Well, since that worked...
Modified by kanjia at 1:27 AM 8/30/2006
Old Aug 30, 2006 | 01:03 AM
  #9533
importdude2000's Avatar
Default Re: (kanjia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kanjia &raquo;</TD></TR><TR><TD CLASS="quote">Well, since that worked...
Modified by kanjia at 1:27 AM 8/30/2006</TD></TR></TABLE>
what tires
Old Aug 30, 2006 | 05:45 AM
  #9534
watsvtecEK's Avatar
Default Re: (importdude2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D 2da A9 &raquo;</TD></TR><TR><TD CLASS="quote">i have a quick questionnn. how do i remove the back seats out of my da hatach. i am goign to the track tomarow and im tryin to shave some extra pounds. is thare any special way? thanks</TD></TR></TABLE>
help
Old Aug 30, 2006 | 08:07 AM
  #9535
wingswestrex's Avatar
Default Re: (D 2da A9)
on the back seats, pull the **** on the top that'll drop the top part down then you'll see some brackets undo those, and then there's i think 1 bolt in the middle of the back seat, undo that, and pull forward the get the hooks from the front part out of the slot and you're good. hope this help
Old Aug 30, 2006 | 08:28 AM
  #9536
POE's Avatar
POE
Default Re: (flaps)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flaps &raquo;</TD></TR><TR><TD CLASS="quote">
thats badass my DA's got around 220k also and it still pulls like brand new </TD></TR></TABLE>
gotta love it. i got great compression and just take car of it, do regular maintance... ya know what honda recomends
Old Aug 30, 2006 | 11:15 AM
  #9537
kanjia's Avatar
Falken ZE-512's 205/45/16. They creep in a little, so I'm thinking about going up to 55, it should fit with no clearance issues...
Old Aug 30, 2006 | 11:21 AM
  #9538
da9wonder's Avatar
Default Re: (jdmkrazie)
[QUOTE=jdmkrazie]shouldnt have painted the oil cap and i hope you sand off the paint off of the letters
I did sand off the letters and the oil cap.... it looked wack so yea
I GOT MY DROP finnaly
yay or nay?
Old Aug 30, 2006 | 11:22 AM
  #9539
da9wonder's Avatar
Default Re: (crxwonder)
o and i painted my front molding so im done painting my moldings :D
Old Aug 30, 2006 | 01:39 PM
  #9540
MJobe's Avatar
!!!!!HELP!!!!! https://honda-tech.com/zerothread/1737655
Old Aug 30, 2006 | 02:02 PM
  #9541
ChaseIntegra's Avatar
Default Re: first car (JasperDA9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasperDA9 &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
I wish somebody knew what that kit was actually for. Looks like it fit pretty good. I'm guessing it's either a GS-R or a Civic Si.
Old Aug 30, 2006 | 02:03 PM
  #9542
MJobe's Avatar
Default Re: (NAalltheWay91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAalltheWay91 &raquo;</TD></TR><TR><TD CLASS="quote">!!!!!HELP!!!!! https://honda-tech.com/zerothread/1737655</TD></TR></TABLE>
Old Aug 30, 2006 | 02:59 PM
  #9543
projectTeG's Avatar
Default Re: first car (ChaseIntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChaseIntegra &raquo;</TD></TR><TR><TD CLASS="quote">I wish somebody knew what that kit was actually for. Looks like it fit pretty good. I'm guessing it's either a GS-R or a Civic Si. </TD></TR></TABLE>
99-00 civic si
Old Aug 30, 2006 | 03:14 PM
  #9544
redlineintegra's Avatar
Default Re: first car (projectTeG)
search username B17Vortech on G2IC ... old member, here's some info he posted:
for B16 use the civic SI kit.
The fit issues only really concern the battery, AC line, and the ABS. Both must be removed unless you don't want to use the water to air intercooled version. The Battery and the AC line are occupying the space for supercharger. (you do need to drill a hole in the clutch cable bracket.) There are no chassis fit issues for the Vortech kit. I did have to do probably the most severe modification of a crossmember anyone's done in order to get a Hi-tech custom Type R header installed. I used a skunk2 Intake Manifold which the aftercooler fit perfectly, I am not sure how tight the aftercooler fit would be if your using a different manifold. It's a tight fit but I was still able to install a front strut tower after the install was done. I do suggest switching your crank pulley with a CRV crank pulley.
One more thing, you can't use your stock power steering. You can change to a 99/00 SI pump and 99/00 SI PS line (you need to use only that model civic, you can't use other models.) or you could just go without PS. I still haven't bought a PS line I have the pump installed
If you email me I will send you my canned answer for everything I did.
http://www.g2ic.com/forums/sho...rtech
Old Aug 30, 2006 | 03:59 PM
  #9545
da9wonder's Avatar
i need to raise the back but yeea
Old Aug 30, 2006 | 06:19 PM
  #9546
K.Quinn's Avatar
hey guys, post pics with accord rear lips for me so i can see what it looks like and how i have to modify it. thanks.
Old Aug 30, 2006 | 06:33 PM
  #9547
whoa its len 2's Avatar
Default Re: first car (redlineintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlineintegra &raquo;</TD></TR><TR><TD CLASS="quote">search username B17Vortech on G2IC ... old member, here's some info he posted:
http://www.g2ic.com/forums/sho...rtech</TD></TR></TABLE>
interesting...
Old Aug 30, 2006 | 06:51 PM
  #9548
2GEN DA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxwonder &raquo;</TD></TR><TR><TD CLASS="quote">
i need to raise the back but yeea </TD></TR></TABLE>
Ya u need to raise the back cause it looks a little low and weird!!!!!
Old Aug 30, 2006 | 08:28 PM
  #9549
hionvtecxda6's Avatar
looks like you have to relocate the prop. valve too
Old Aug 30, 2006 | 10:47 PM
  #9550
t . b o z's Avatar
