DA Integra's Only
Old Feb 2, 2012 | 06:11 PM
  #50801
Kevin's Avatar
Default Re: DA Integra's Only
Old Feb 2, 2012 | 06:17 PM
  #50802
be18see1's Avatar
Originally Posted by Builda'Teg_92
So it's just a bracket that wrapped around the back of the support and got bolted into?
I'm guessing you had threads on the IC to put bolts in?
The IC had threaded mounting locations on it already. I just made a couple brackets that are bolted to where the bumper cover attaches.
Old Feb 2, 2012 | 06:37 PM
  #50803
Mattb16teg's Avatar
Community Builder
Community Influencer
Originally Posted by g2_teg_
I'd drive 3 hours for $150.
Guess you haven't driven to Philly much?
Tolls alone are $20 round trip, plus gas, def not worth it in the end.
Originally Posted by be18see1
I'd like to be mid 400's.
It's not that fun!
LoL, I need a new electronic controller.
Old Feb 2, 2012 | 07:49 PM
  #50804
OldSkoolDa91's Avatar
herb...link didn't work for me?
Old Feb 2, 2012 | 08:01 PM
  #50805
90HondaDA's Avatar
would you guys recommend spending the money for a k24 block for a k20a2 or just build the a2
Old Feb 2, 2012 | 08:51 PM
  #50806
ELIDA9's Avatar
Originally Posted by Kevin
wish I had the budget to attempt this.....does the hood shut all the way?
Old Feb 2, 2012 | 09:03 PM
  #50807
i'm going to ASSume it does since the webbing is cut out, but no hole in the hood?
Old Feb 2, 2012 | 09:38 PM
  #50808
FelipeIsJDM's Avatar
That K20 swap is too sexy for words...
Old Feb 2, 2012 | 10:05 PM
  #50809
hb420's Avatar
Thread got deleted, two ht members called skunk2 out on another forum and this one so they decided to do this... http://cms.skunk2.com/id/777/Skunk2-Bounty-Cash-Reward/. The skunk2 sponsor on k20.org made a fake screen name, acted like he had a k series DA, needed help and asked for his address so he could bring his teg to his house and the member figured out who it was and flamed him even more lol.
Old Feb 2, 2012 | 10:10 PM
  #50810
btwentyteggy's Avatar
ALL PRAISE THE DA!
  #50811
Charlie Moua's Avatar
****giving back to honda-tech for what i've learn over the past years and trying to teach my little brother the same ****
First of all I wanted to give thanks to the following people:
Tou - P.R.E
Keep in mind I only have 6 people who I completely trust with my friendship, cars & money and Tou is one of them. I’ve known him & his younger brothers since Jr. High. Thanks for walking me through this engine build and sharing your knowledge.
Jordan – Jordantuned.com
Of also one of the 6 friends who I trust & care about. I’ve known for 8yrs. He’s always has my back making sure I don’t chew off more than I can handle when it comes to Hondas.
Pat – R.D.R
Same as above, one of the guys that I met 8yrs ago which we just seemed to connect well.
He’s always coached me along the way just like tou & Jordan. Pat is probably the best “teacher” I now when it comes to drawing things out & explaining how things works in simple terms. I’m still waiting for him to jump back in the game when he’s ready.
Chris & MAP
MAP provided the best rock bottom pricing & has flexible dyno hours.
Buy doing this, it helped us greatly with the our B20 rebuild goals & data collecting.
Most importantly, Chris does care about the local honda guys. He's genuinely ask good questions about Honda which he's still learning & chatted with the guys who came out to watch/support.
This is my brother, Alex’s motor car which was rebuilt after his jdm b20b I swapped in spun a bearing only after 8 months of heavy abuse from Alex. I use to have a build thread on mnhondas but I didn’t see any benefit to it due to fear of theft.
Nonetheless, I still wanted to show what can be accomplished with simple parts and knowledge. Before you ask my why I didn’t do B20V, I’ll just say because my little brother doesn’t deserve it yet. He needs to learn to appreciate how to make power before I just hand it over to him.
The plan was 2stage build:
1st stage is B20 rebuild with cams 155-160whp
2nd stage will be small turbo to hit 270-280whp = coming end of 2012
Here is the break down of general parts used:
JDM B20B 8.8:1cr (84x89)
ACL race bearings mains & rods ***MAP***
ARP rod bolts *** MAP***
ARP head studs *** MAP***
JDM B20B P75 head
Milled head - P.R.E spec to raise compression from 8.8 to 9.7cr
RDR “Pat” race spec 5 angle valve job (no porting)
Delta 272 cams
Rocketmotorsports spark plugs
Rocketmotorsports snap-fit valve springs
Stock seats & retainers
Ebay cam gears
Blox intake manifold & B18a1 58mm throttle body
Ebay Tri-Y replica header “small tube” 2.5” collector
2.20” crush bent exhaust piping
Baseline pull vs. last pull
Jordan came over 9pm Wednesday to provide base map & 20mins of street tuning. We put it through a few hours of driving & made sure he engine sealed up well 215psi across the board.
Alex’s B20b vs. jdm B16a2 (decent header, intake, exhaust & tuned)
This is why I dislike b16 for NA. Most people pay $1900-2200 for a jdm b16 swap + money for bolt ons and still doesn't have a usable powerband. IMHO I'd only build a B16a NA as a practice car lapping/drag or teaching my sons how to drive cause those suckers never seem to die or hardly spin bearings.
Alex’s B20b vs. my b18c1 gsr
This is back during 2009 MAP dyno day in the summer.
GSR with skunk2 IM, gsr tb, hondata gasket, stock header, 60mm rsr full exhast. Back when we swapped in the BONE STOCK B20B (no header) 6500rpm redline, Alex's DA B20 2550lbs still killed my EF Si GSR 2300lbs in any racing conditon up to about 80-85mph in 4th. I know this new motor would certainly kill most GSR swaped civic up to 100mph.
The final results speak for themselves.
You don't need a lot of money or fancy parts to make good power.
Don't chase other people, do reasearch, ask good questions and be realistic about what you can do financially & I promise MAP will help you out with best pricing on parts.
I'm no expert or not saying this is the only way to build it.
I'm just sharing you what we've done and you can take what you want from it.
I'm very pleased with the results & we were able to stay within budget.
This should be the standard of what budget NA b-nonvtec motors build should comprise of. Too many times I see people waste money on the wrong parts.
Considering b20b dyno at 128-130whp and 120tq
We spent
$160 on cams
$75 cam gears
$165 valvesprings
$170 header
$80 used block intake manifold
$650 in aftermarket parts for gains 25whp gains and 10-12tq is money well spent.
  #50812
here are some pictures of the build
reason for the tear down..... spun oem bearing cause rod bolt was loose
Ebay
Milled
Honed stock rods
delta 272
RMS - snap fit to oem retainers
Old Feb 3, 2012 | 03:12 AM
  #50813
hondahead_dave's Avatar
here is my grill with my intercooler behind it, you do have to shave the back down a bit...
Man I need a new clutch on my fa5, I jacked it up over the weekend in D.C., now when I pull up to lights, sometimes I have trouble putting it in gear, man I am getting sick of this car.......
Old Feb 3, 2012 | 11:30 AM
  #50814
g2_teg_'s Avatar
[IG]http://i171.photobucket.com/albums/u297/glokology/integra2/k24build/b1e102c3.jpg[/IMG]
best car in thread.
what header is that? how was the fit?
biggest intake filter in the country.
Old Feb 3, 2012 | 11:31 AM
  #50815
shifty92's Avatar
best car in thread.
top 5 lol
Old Feb 3, 2012 | 09:36 PM
  #50816
after seeing all the comments on fb about it today, i figured that's what it was. i didn't read any threads, but got enough of an idea of what happened just from comments.
all i have to say about is, i love my skunk2 intake manifold on my ls. i noticed an obvious difference with it and their manifolds have been proven many times before.
either way, ALL companies need to just be legit n honest from the get go and save all this bs. being legit n honest and having good customer service is what keeps businesses alive, especially in an industry such as this
Old Feb 4, 2012 | 11:52 AM
  #50817
90HondaDA's Avatar
New DD???
Sooo we couldn't resist but pick this thing up
Cost us $500 yes i said five hundred lol has 231k miles, runs perfectly is in great condition and gets 45 mpg. Clutch needs some adjusting or replaced but no biggie
Old Feb 4, 2012 | 07:53 PM
  #50818
not gonna lie... pretty jealous of that deal! lol. nice find man
Old Feb 4, 2012 | 10:04 PM
  #50819
Great find! Gonna build it down the road or is it strictly a daily?
Old Feb 5, 2012 | 08:22 AM
  #50820
RABI_T89's Avatar
Nice man, looks good as well! Any engine bay pics?
Old Feb 5, 2012 | 10:54 AM
  #50821
jesvtec's Avatar
[IMG] Uploaded with ImageShack.us[/IMG]
snow in belgium
Old Feb 5, 2012 | 01:16 PM
  #50822
90HondaDA's Avatar
Well if we can figure out this over charging issue we discovered yesterday we might put the gs-r in it.
Old Feb 6, 2012 | 08:52 AM
  #50823
Mattb16teg's Avatar
Community Builder
Not DA related but our homes progress is moving along:
Old Feb 6, 2012 | 10:48 AM
  #50824
shifty92's Avatar
^^nice and good luck on the future home!!!
Old Feb 6, 2012 | 10:57 AM
  #50825
Mattb16teg's Avatar
Community Builder
Thanks man! Just a nice little place to get started.
