DA Integra's Only
Old Dec 18, 2011 | 09:27 PM
  #50251
OldskoojdmDA9's Avatar
Default Re: DA Integra's Only
Originally Posted by EFcivicJDM
how do ye do the thumbs up thing?always meaning to ask ha
Haha that gave me a good laugh.
: + thumbup + : (altogether) =
You can also choose it from the 'Smilies' sidebar to your right.
Old Dec 18, 2011 | 11:03 PM
  #50252
OEM92GS-R's Avatar
Installed the ASR 24mm rear sway bar, Nd brace on the DB2 on friday.feels much better at sharp curves .Anyone else running this kit? Currently running it on funtion nd form coils, front; 10 Kg and rear; 6 Kg. sorry for shitty cell pic.Name:  my asr.jpg
Old Dec 18, 2011 | 11:58 PM
  #50253
DAman9's Avatar
nothing super special, b20 with p8r head and function form type 1's, and white webs
[IMG][/IMG]
[IMG][/IMG]
Old Dec 19, 2011 | 12:22 AM
  #50254
djkobe's Avatar
Originally Posted by tougetuned_ef
yeah these wheels have been in storage for 9 of there 11 years of life. they are mint!
have you recently bled your cooling system? i was having problems with my car hesitating with my old LS and i had to bleed the crap out of it to get it to run correctly. make sure your fans are kicking on and and its not overheating if left at idle. also clogged cat may cause it too if its jammed up and cant flow right. idk check them to rule them out. also if you can get your hands on another ecu that will rule it out. they are a dime a dozen at junk yards
I recently flushed the system and made sure that it was completely bled but I'll bleed it again just to be on the safe side. My fan was working after I replaced the coolant sensors on the side of the head and quit again not too long after. It never even gets close to hot unless I'm Idling for a really long time on a hot day, I know the thermo is good because the temp stays normal unlike my last failsafe that failed. Plugged cat isn't an issue because im running straight 2 1/4 from jg series edlebrock headers, after I put the system on it ran phenomenal. BUT I had to put the stock manifold back on while I was waiting on heat wrap for the header, and the car felt incredibly similar to this "dragging" feeling it has currently.
Old Dec 19, 2011 | 02:21 AM
  #50255
Mattb16teg's Avatar
Community Builder
Community Influencer
Originally Posted by Bond
Good stuff. I bet it feels good to hit the road with it.
Started to realize I'm getting close to finishing my DA. As for mechanical stuff I'm almost done my parts gathering. Now I'm moving on to exterior cosmetics.
Nice I can't wait to see your car up and running!
It does, especially since I had so much minor stuff to do to get it moving again.
I hadn't driven it in so long I was worried. I need an alignment really bad!
Power is so much smoother and packs more of a punch!
Old Dec 19, 2011 | 06:39 AM
  #50256
MaltBeer's Avatar
have you replaced your wheel bearings? if he had to beat on the axels to get them out he may have ruined your bearing on one or both sides.
I thought about the wheel bearings and asked him if that was it and he firmly said "no" lol so I dunno...but I'll look into it. Thanks for the heads up on that though.
Old Dec 19, 2011 | 06:45 AM
  #50257
tougetuned_ef's Avatar
Originally Posted by OEM92GS-R
Installed the ASR 24mm rear sway bar, Nd brace on the DB2 on friday.feels much better at sharp curves .Anyone else running this kit? Currently running it on funtion nd form coils, front; 10 Kg and rear; 6 Kg. sorry for shitty cell pic.Attachment 246672
i am running this bar with heim joint endlinks. made such and impressive difference. but i was having a problem with the car bouncing at high speed around some backroads in my area. had to start taking it easy. i think my shocks may need to be replaced also.
i had to bleed my car for over a hour. even at 1:15 of the car running it still had tiny bubbles coming out. i even have a brand new thermostat and fan switch and the car will have temp spikes if the fan temp is left on cold. im running a 00 civic si b16 with a obd1 b16 im. the cooling system has one tap more on the im than my ls did which makes me have to run a short piece of hose with a plug in it. i have tried this hose a few different ways but still get a these spikes that i couldnt get rid of. before i bled it for over an hour tho i was getting these hesitation feelings from the motor.
in my crv i would hear this humming noise while i was driving. and then i had 2 studs break which made me have to replace it and bam the noise was gone.
Old Dec 19, 2011 | 06:51 AM
  #50258
hb420's Avatar
Anyone getting their teg anything for Christmas? Mine is getting suede nardi wheel, mugen rep sides, firewall ac delete plug, antenna delete plug, es shifter bushing kit, oem clutch cable, oem air filter, new distributor, new radiator, m3 style trunk lip and a new front lip. About to take a trip to the junkyard and see if I can find a 90-91 bumper in good shape.
Old Dec 19, 2011 | 07:23 AM
  #50259
OldSkoolDa91's Avatar
good luck herb. if you were closer, the one junk yard i go to all the time has a couple bumpers, and the one is damn near mint
Old Dec 19, 2011 | 07:29 AM
  #50260
Lord Helmet's Avatar
for christmas: bigger turbo, upgrade the radiator, and more tuning
Old Dec 19, 2011 | 07:38 AM
  #50261
Mattyg2's Avatar
Registration tags for christmas
Old Dec 19, 2011 | 07:49 AM
  #50262
MSchu's Avatar
My Name is Nobody
1250+ pages and still rocking...
nice!
Honda, are you listening!
Old Dec 19, 2011 | 09:12 AM
  #50263
if its oem you should scoop it up. i prolly picked from 30 different das in the philly area and not one had a decent oem bumper.
i wanted to snap a shot of the page when it was 2000 pages and 50k posts! damn!
Old Dec 19, 2011 | 11:39 AM
  #50264
kiDchaos's Avatar
herb, good luck on that. I'm trying ot find a mint 92 - 93 front and rear bumper for mine as well. Bumpers are the first to go around here i guess.
Old Dec 19, 2011 | 11:51 AM
  #50265
my car currently has a certifit front bumper and it doesnt fit well at all. and cracked on the farthers left corner where it meets the fender. the rear bumper only has a little scoop of plastic missing on the trim.i really need to find an oem right fender cause the one on there is a pos.
Old Dec 19, 2011 | 01:42 PM
  #50266
hb420's Avatar
Two Junkyards and one had a 93 bumper but had deck screw blasted into it to hold the bumper on and the other junkyard had a 90 bumper but it looked like it was cut with a jigsaw on one side. I might just attempt to repair my oem bumper with $80 of material ftl
Old Dec 19, 2011 | 01:55 PM
  #50267
Builda'Teg_92's Avatar
^Why not get an aftermarket bumper? i got mine new for 120$.
Old Dec 19, 2011 | 02:00 PM
  #50268
hb420's Avatar
Because i want good fitment and for the bumper to not break apart like i've seen aftermarket bumpers do. My friends Teg got backed into by a car that was parking and the bumper shattered into multiple pieces from a 2 mph hit.
Old Dec 19, 2011 | 02:04 PM
  #50269
I see....my fitment was pretty darn good, i hope i never have to test its duability lol
Old Dec 19, 2011 | 02:13 PM
  #50270
hb420's Avatar
In all reality you could make them fit good with some work, but I'm crazy about the front end fitment being perfect with even lines. I've replace every piece that's needed to mount the front bumper, nothing beats factory fitment... So i'm trying to get it back to that.
Old Dec 19, 2011 | 03:14 PM
  #50271
my bumper has a 3/8" gap betreen the bottom of my one pieces and the bumper. ive tried everything to get it to sit closer but nothing works. oem is def the best way to go with body panels. even my vis sits like **** with weird gaps around the lights and front end of the fenders. ive tried messing witht he little bumpers for it but one side sits up twice as high as the other. prolly from the hood stand making it twist.
Old Dec 19, 2011 | 03:54 PM
  #50272
guess i got pretty lucky? my WHOLE front end is aftermarket lol
im in the mood for posting now, here is some work i did on the DA yesterday.
my aftermarket panels lol \/....i just hate body work so much.
Old Dec 19, 2011 | 04:19 PM
  #50273
DumaDA's Avatar
lookin good
Old Dec 19, 2011 | 04:24 PM
  #50274
slammedg2's Avatar
if u were closer id say come get this back bumper i have laying around its red idk what color u need but its just sitting around
Old Dec 19, 2011 | 04:53 PM
  #50275
ELIDA9's Avatar
paint is looking good
here is a rolling shot from the tunning session last friday night. She put down 170hp @ the wheels ( 198hp crank ) for a B16 @ 9,000 rpm.
