DA Integra's Only
Old Jun 6, 2011 | 08:59 PM
  #47701
tegtuner01's Avatar
Default Re: DA Integra's Only
Originally Posted by 91b18a1ls
**** this thread turns me on, who needs **** when you've got da's for days. Guess I'll go ahead and throw up some pics an info on my baby =]
I need to get a new photo of my bay. I cleaned it up a lot and did a mini wire tuck.
Heres a list of what i've got done to her,
JDM B16A SIR II motor
S4C Transmission
16" Rota Circuit 8 rims
Maxxis 205/45/r16 Tires
Skunk2 dual bend short shifter
Blox 490 Neo Chrome limited edition **** ****
Hasport transmission mount
Hasport cable to hydro conversion kit
AEM Cold air intake
NUESPEED strut bar
ASR subframe brace
JDM one piece headlights
RS*R ExMag exhaust
DC Sports 4-2-1 header
Skunk2 full PRO-S coilovers
P28 ecu (chipped)
Skunk2 front camber kit
Megan Racing rear camber kit
Aftermarket sunroof
Custom red painted needles
Hondata intake manifold gasket
Mini wire tuck
hey.
Old Jun 6, 2011 | 09:04 PM
  #47702
fragine's Avatar
i want one!!!
Old Jun 6, 2011 | 11:58 PM
  #47703
OldskoojdmDA9's Avatar
Originally Posted by kNOwLedGe.
Haha that made my night. Thanks dude!
Old Jun 7, 2011 | 11:54 AM
  #47704
91b18a1ls's Avatar
Originally Posted by tegtuner01
hey.
Your from Austin too, Do I know you?
Old Jun 7, 2011 | 12:07 PM
  #47705
hb420's Avatar
Wouldn't you ask yourself if you knew him instead of asking him if you knew him? lol
Old Jun 7, 2011 | 12:19 PM
  #47706
Mattb16teg's Avatar
Community Builder
Community Influencer
Cocaine is a hellava drug!
Old Jun 7, 2011 | 01:44 PM
  #47707
g2_teg_'s Avatar
Originally Posted by tougetuned_ef
i just cant figure out why it will not start. is it just the eg that you use the gsr harness with. anybody have any ideas of why it wont start. im about to do a compression test to make sure thats not the problem. the motor sat for 2 1/2 years before we pulled it out of the car and then put it in here. i also think that the headgasket might be bad cause i keep having this coolant spot show up after a little bit and it looks like its coming from the front of the motor at the hg.
yes. In my EG i have a 2001 GSR engine harness. That is what it's like owning an EG. When you have a DA, nothing cool is plug-and-play.
It doesn't sound like injector wiring is your issue.
Are you sure that the combustion chamber is not getting sufficient fuel? What about spark?
Old Jun 7, 2011 | 02:21 PM
  #47708
91b18a1ls's Avatar
No, cause no where does it say his name. nor do I know people by their usernames, and I can't remember peoples names anyway
Old Jun 7, 2011 | 02:23 PM
  #47709
Mattb16teg's Avatar
Community Builder
Exactly, then given that same sentence/thought, then how would he know you?
Old Jun 7, 2011 | 02:48 PM
  #47710
91b18a1ls's Avatar
whatever nevermind
Old Jun 7, 2011 | 03:21 PM
  #47711
tougetuned_ef's Avatar
here is my post from the beginning of the last page. i think im getting it to the combustion chamber. the plug does not wreak like gas but i can smell a hint of it. and i do have spark.
ok so the car doesnt have the resistor box but here is what my issue is. the car will just start up for a split second on every 3 key turns. i am getting spark and fuel to the fuelrail at the first nut. i have an obd2 gsr harness and from what im reading i need to use this but is this the only way? i didnt know that i could just use it so i stole plugs from it like oil pressure plug, big dizzy plug, vtec,and knock plugs, and the injector plugs. i would like to run the obd2 injectors but i was also reading it just not that simple. i need to know if i should just put the gsr harness back together? it would take me about an hour or 2 but do i really need to do this. any insight on all of this would be greatly appreciate it.
here is my set up:
00' si b16 which is obd2 my car is a 92' RS (all plugs in b16 are still obd2, motor has 56k)
obd1 b16 intake mani with spoon ventuli plate
obd2 tb with map sensor on the top of it
p28 ecu chipped
obd1 LS injectors so still have wire clip plugs obd2 fuelrail
fpr with guage reading 36lbs
obd2 big dizzy plug
obd1 LS wiring harness
obd0 LS iacv
new bosch plat plugs
oem plug wires
obd1 alternator
fuel filter was fine when i took it out of my grey da.
Old Jun 7, 2011 | 03:27 PM
  #47712
g2_teg_'s Avatar
well if you have fuel, and spark, then you probably have an issue with air, timing or compression...
couple questions. First, when the engine runs for a split second are you able to keep it running by hitting the gas pedal? Second, does the B16 throttle body have a FITV on the bottom?
Old Jun 7, 2011 | 05:26 PM
  #47713
it will not stay running with the gas pedal. its an obd2 em1 si tb and obd1 b16 intake mani. no fitv. there is air cause there is not intake tube hooked up. and i checked the timing and thats good.
i just had a thought a few moments ago. this motor was in a really bad accident about 2.5 years ago. the car hit a tree sideways at 100mph and it ended up upside down for a brief moment before it fliped back over onto its wheel again. now what led me to this theory was that the plugs were completely white when i pulled them and the rad was cracked. maybe the car ran dry for a min or 2 before it shut off.
my brother was the one driving and he said he woke up in the pass seat and crawled out of the car. he was out when he landed so he doesnt know how much time passed before he woke up so we assume he didnt shut the car off himself. this might explain the coolant on the corner of the head. i didnt do the compresion test today cause i worked late and im tired to be honest. when i get done tomorrow if i dont have to work at night i will do it. that should tell me something.
heres the car it came out of. my brother walked away without a scratch. dont drink and drive!!! the guy in the back was coving his head from the rain.
Old Jun 7, 2011 | 08:21 PM
  #47714
91b18a1ls's Avatar
Damn...that sucks! Good to hear he was alright though.
I made a better video earlier after I got my chip retuned
http://vimeo.com/24805365
Old Jun 8, 2011 | 04:11 AM
  #47715
Mattb16teg's Avatar
Community Builder
MSD 2 step?
You will find better results pre-loading the drivetrain instead of dumping the clutch.
Old Jun 8, 2011 | 06:19 AM
  #47716
be18see1's Avatar
Originally Posted by Mattb16teg
MSD 2 step?
How do you pre-load the drivetrain? Still learning
Old Jun 8, 2011 | 06:40 AM
  #47717
Mattb16teg's Avatar
Community Builder
Not sure if serious?
Would you rather me say pre-load the clutch?
Old Jun 8, 2011 | 08:35 AM
  #47718
be18see1's Avatar
No I'm serious. I really don't know.
Old Jun 8, 2011 | 09:00 AM
  #47719
91b18a1ls's Avatar
MSD 2 step?
Nope, Crome fuel cut. I'm with that guy, I don't know what your talking about either
Old Jun 8, 2011 | 09:13 AM
  #47720
90HondaDA's Avatar
To pre load the drivetrain you hold the e brake put it in first reeve it to like 2-3 k hold that let the clutch out to where it grabs but slips. At this point the drivetrain is preloaded, this prevents the harsh clutch drop and the stress of that on the axles and trans. More grip also.
Old Jun 8, 2011 | 10:52 AM
  #47721
Mattyg2's Avatar
Sounds like the clutch will be put under a lot of stress. Silly draggers
Old Jun 8, 2011 | 11:02 AM
  #47722
Mattb16teg's Avatar
Community Builder
They make products to support the stress.......
Old Jun 8, 2011 | 06:05 PM
  #47723
be18see1's Avatar
ah okay. I understand. I don't think I'm to that point quite yet.
Old Jun 8, 2011 | 06:21 PM
  #47724
91b18a1ls's Avatar
Yea, i'm just gonna keep dumping my clutch like I've been doing since I learned how to drive. I rarely ever do it anyway unless I make videos like this. I have launch control but I do 40 rolls lol
Old Jun 9, 2011 | 11:30 AM
  #47725
Sup guys! Just another update.
Yesterday turned out to be a pretty nice day in Seattle so we did some rolling shots of my newly acquired NT03's. Here we are!
Photo credit: Tim Oum!
