DA Integra's Only
Old Jan 11, 2010 | 12:52 PM
  #35201
Ef9vsDa9's Avatar
Default Re: DA Integra's Only
Originally Posted by EF_338
i left the lips, skirts, seats, and turbo kit.
you must of sold it 5 digits
Old Jan 11, 2010 | 01:02 PM
  #35202
slammedg2's Avatar
a little teaser from the last shoot
pure sex
Old Jan 11, 2010 | 01:11 PM
  #35203
kNOwLedGe.'s Avatar
Originally Posted by 1200 Hobos
Yes it can. K20 DA9. Check out the track widths on a DA and a DC.
Eh. The DA chassis is far inferior in terms of rigidity. I still love it, though.
Old Jan 11, 2010 | 01:14 PM
  #35204
slammedg2's Avatar
here is a pic of my car i took yesterday i got some new wheels
Old Jan 11, 2010 | 01:20 PM
  #35205
DumaDA's Avatar
advans or rotas?
Old Jan 11, 2010 | 01:24 PM
  #35206
slammedg2's Avatar
the advan reps idk who makes them i dont care hahathey wont laast long on there i want something weird
Old Jan 11, 2010 | 01:33 PM
  #35207
1200 Hobos's Avatar
How so? In terms of Apples to Apples here. An LS for an LS or an RS for an RS, no Type-Rs. I think they would be equal unless you bring a Type-R into the equation.
Old Jan 11, 2010 | 02:23 PM
  #35208
kNOwLedGe.'s Avatar
From my friend Pat's (tnd2gen) website:
Because of structural weakness common to the DA chassis, it is the one place of importance in overall vehicle improvement. The amount of high-tension steel used in the DA chassis is 25% less than in that of its predecessor, the DC, which also consists of 4-plate welds (not incorporated on the DA) resulting in a 125% stiffer chassis. The DC chassis also features increased stiffeners and spot welds, and an overall higher load capacity due in part to its
superior monocoque design.
Even when comparing the DA chassis to a base model DC chassis, it is still inferior.
Old Jan 11, 2010 | 02:33 PM
  #35209
1200 Hobos's Avatar
Actually, that is describing a DC2-R chassis, exactly why I asked for an Apples to Apples comparison... Base model DC2s don't have this superiority. How do I know? Increased stiffeners, in other words, bars.
Both chassis have spot welds because a robot can't reach every area.
Even so, on the topic of stiffness, when you build a true weld-in cage it makes up for any inferiority in stiffness!
The bit about steel, 25% less steel = 25% less weight. So it's stiffer, It's also now heavier.
Old Jan 11, 2010 | 02:41 PM
  #35210
Ef9vsDa9's Avatar
copy n past ^^^
Old Jan 11, 2010 | 02:46 PM
  #35211
Brice.Hayden's Avatar
still more than you are bringing to the table. which is nothing.
Old Jan 11, 2010 | 02:48 PM
  #35212
kNOwLedGe.'s Avatar
Actually, that is describing a DC2 chassis, exactly why I asked for an Apples to Apples comparison... Base model DCs don't have this superiority. How do I know? Increased stiffeners, In other words, bars.
The Si-VTEC and SiR Integras (also GS-R) are still "base models" (as in, not Type R) and are also DC2 chassis. These are still superior to the DA chassis in terms of rigidity. The mere design of the chassis itself is superior, thus any DC (whether DC2 or DC4) is still superior to a DA chassis. It has little to do with the bars found on the Type R.
Old Jan 11, 2010 | 02:49 PM
  #35213
kNOwLedGe.'s Avatar
Originally Posted by Ef9vsDa9
copy n past ^^^
Shouldn't you be somewhere spraypainting some OEM wheels hot pink?
Old Jan 11, 2010 | 02:55 PM
  #35214
The very last pic of my car before I sold it. Kinda miss it somedays.
Old Jan 11, 2010 | 03:12 PM
  #35215
1200 Hobos's Avatar
What I meant was DC2R. Not all DC2s have the chassis of the R type. The R is the most sought after Integra not only because of the motor but all the attention to detail.
When comparing an LS DC and an LS DA the DC didn't get any special treatment. Ok, it's the 3rd generation integra so obviously there will be some improvements over the previous chassis. But to say it's FAR superior is being a bit overzealous.
When the cages go in, those little chassis differences even out and it becomes a game of grip.
How about that neat little design feature they call the front crossmember on the DA? DC2 chassis doesn't have this, it's a key point for grip under serious braking, it takes care of torque steer on corner exit aswell.
  #35216
Mattb16teg's Avatar
Community Builder
Community Influencer
Originally Posted by hondahead_dave
morning all, went to an integra meet yesterday, 20 degree weather wasn't fun. It was fun driving my car, but the temp gauge went up to very hot, and I don't know why. I was just sitting at the gas station with the car running, don't know why it got hot. I turned the car off, turned it back on and drove the temps went back to normal, what could that be? I know in the summertime it does it as well, but it is like 20 degrees, didn't think it could do it then......
Damn Dave, couldn't holler at me?
I woulda been down, been driving the DA while I fix the CL(on that not I ordered a new dizzy, cap, rotor and plug wires). Hopefully that'll fix it!
As for your overheating if the car overheated while sitting you may want to check your fan. Is it on, is it blowing the right way?
Since it's been more then once its def not an air bubble.
I battled this problem last year and it ended up being a small leak in my head gasket. Pull your rad cap off and start the car, if it sprays coolant out of the rad neck your hg is blown. If not I'd say flush the cooling system, change your thermostat and bleed the system correctly.
I'm game to help, just lemmie know!
Old Jan 11, 2010 | 03:18 PM
  #35217
EF_338's Avatar
lofl
nice and simple, love rpf1's
  #35218
kNOwLedGe.'s Avatar
Yes, the sky is blue and water is wet.
Trust me, I know the differences between the DC2 and the DC2-R chassis.
I can agree with that.
Old Jan 11, 2010 | 03:26 PM
  #35219
1200 Hobos's Avatar
That's what caught me off guard in the first place. Cheers.
Old Jan 11, 2010 | 03:42 PM
  #35220
kNOwLedGe.'s Avatar
BAHAHAHA! One of my friends told me he saw a picture of me on Alphanumeric's blog site.
I was on my way to the Super Lap Battle finals at Buttonwillow Raceway in November. I decided to rock my old school A# sweatshirt from back in 2000 with the B16A cutout on it. Me and my homies stopped at Carl's Jr in Gorman for some shitty food. Turns out some dudes from A# were there too (they sponsored the event) and were jocking my sweatshirt. One dude asked to take a pic of it, then came back an gave me one of the A# Super Lap Battle shirts for free.
http://alphanumericbrand.com/news.ph...um=2&m=2009-11
Me + 7AM + baked = funny picture.
Old Jan 11, 2010 | 03:51 PM
  #35221
Ef9vsDa9's Avatar
Old Jan 11, 2010 | 03:53 PM
  #35222
Ef9vsDa9's Avatar
STFU!
Old Jan 11, 2010 | 04:03 PM
  #35223
DumaDA's Avatar
you could have just clicked the multi quote button next to the quote button instead of making multiple posts.
Old Jan 11, 2010 | 04:08 PM
  #35224
Ef9vsDa9's Avatar
Old Jan 11, 2010 | 04:18 PM
  #35225
DumaDA's Avatar
Seriously if thats all that you're going to post just dont respond at all. Otherwise make your post worth while so people dont think you're only trying to post count
