DA Integra's Only
Old Nov 11, 2005 | 02:06 PM
  #4726
temp's Avatar
Default Re: (kNOwLedGeDA9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kNOwLedGeDA9 &raquo;</TD></TR><TR><TD CLASS="quote">
1.Toda may be the only out of the three that makes lumpy cams, but the Mugen and Spoon cams that are not released to the public get much more aggressive than Skunk2 stage 1.
2. .25mm does make a world of difference...TOO BAD I TYPED .025mm. .25mm is outrageous. .025mm is the standard thickness milled off of cylinder heads when trying to bump up compression.
3. I had a friend that built the B16A2 in his 00 EM1. CTR pistons in it, running LUMPY *** JUN Type III camshafts, and stock ITR valves. Never had a problem with clearances. Any smart person will clay the engine to check piston to valve clearances first anyway...
4. "Fact of life" my ***. You still don't know what you're talking about. A thin head hasket will not make your pistons hit your valves. Especially in ChaseIntegra's engine, which will be using P72-00 or P73-00 pistons, no matter what cams he is using (if he is using stock sized valves). Shut up and stop giving people FALSE tech advice.</TD></TR></TABLE>
1) and do they use their thin head gaskets? prove it
2) .025mm will still make a large difference, you are talking **** that is already on the virge of breaking as it is and you want to mill a head, get a thinner headgasket, get lump cams and advance that intake cam?...i will be the one pointing and laughing at you when you pull apart your motor and you have holes in your pistons
3) you are right, claying the motor is the best thing to do, however how far advanced is your friends intake cam? is your friend using a thinner head gasket? things you neglected to mention.....tsk tsk
4) reading comprehension &gt; you, i will quote and BOLD the **** for you since apparently you cant read, or some ****
"you can put b16b pistons in a b16a block with STOCK cams and not hit valves to pistons, i guarantee you that once you get your cams you get cam gears to ADVANCE THE ******* INTAKE, thinner headgasket on top of that your valves slape your pistons, fact of life."
this concludes our broadcast day.....CLICK
Old Nov 11, 2005 | 02:11 PM
  #4727
kNOwLedGeDA9
Guest
Posts: n/a
Default Re: (temp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">
2) .025mm will still make a large difference, you are talking **** that is already on the virge of breaking as it is and you want to mill a head, get a thinner headgasket, get lump cams and advance that intake cam?...i will be the one pointing and laughing at you when you pull apart your motor and you have holes in your pistons</TD></TR></TABLE>
WTF??? Who said anything about using a thin gasket AND milling a head? That's just retarded. You do one or the other.
You really think I'm that dumb?...or are you trying to twist my words so you can make me look stupid?
Old Nov 11, 2005 | 02:12 PM
  #4728
digitalHorizon's Avatar
wow it looks like honda-tech in here.
Old Nov 11, 2005 | 02:15 PM
  #4729
temp's Avatar
You really think I'm that dumb?...or are you trying to twist my words so you can make me look stupid? </TD></TR></TABLE>
i dont have to twist anything to do that
Old Nov 11, 2005 | 02:22 PM
  #4730
kNOwLedGeDA9
Guest
Posts: n/a
Default Re: (temp)
i dont have to twist anything to do that </TD></TR></TABLE>
C'mon man. Don't tell me I suck at reading comprehension when you are going in different directions.
An engine without PCT pistons can have a thin gasket OR a milled head with lumpy cams and not have pistons slapping valves. A B16A with PCT pistons CANNOT use a thin head gasket or milled head and lumpy cams without pistons slapping valves. Never did I say you could use a B16A with PCT pistons, ON TOP OF having a thin gasket or milled head, and lumpy cams. I don't know where you got that from.... you are right though. That will put holes in your pistons.
It is possible to have a stock JDM ITR engine with lumpy cams and a thin gasket work out fine. It's done ALL THE TIME. You're saying that this setup will have pistons slapping valves?
Old Nov 11, 2005 | 02:43 PM
  #4731
kNOwLedGeDA9
Guest
Posts: n/a
Default Re: (temp)
You do also realize that most aftermarket camshafts use a lot of overlap (measured in degrees ABDC). The cams are ground so that there is a point where the intake and exhaust valves are open at the same time. This is done to account for the high revving properties of the camshafts, to increase air intake at high engine speeds. This higher level of valve overlap is designed so that YOU WON'T HAVE TO ADVANCE THE INTAKE CAM to develop 8,500+ RPM power. This valve overlap reduces dynamic compression ratio at low RPM, and this is why you must use higher compression to maintain low end power when switching to high-lift cams.
Advancing the intake cam shouldn't be a factor when using good cams like the JUN III and Toda B/C. They keep in mind that piston to valve clearances will be tight. This is how my friend used JUN III cams with PCT pistons with no clearance issues.
Old Nov 11, 2005 | 02:59 PM
  #4732
temp's Avatar
nope, not saying that, i am saying that when you swap cams you dont leave your cam timing stock, you advance your intake, thus lowering the valve clearance, etc.....
Old Nov 11, 2005 | 03:13 PM
  #4733
redlineintegra's Avatar
Default Re: (temp)
DA pics only guys, take the argument to IM!
Old Nov 11, 2005 | 03:18 PM
  #4734
adiDAs's Avatar
comeon man knowledge is one guy that knows his **** don't try him.
newayz back to subject heres a teaser on mine
Old Nov 11, 2005 | 03:19 PM
  #4735
temp's Avatar
Default Re: (adiDAs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adiDAs &raquo;</TD></TR><TR><TD CLASS="quote">comeon man knowledge is one guy that knows his **** don't try him.
says the man with 12 posts
Old Nov 11, 2005 | 03:26 PM
  #4736
GrayT's Avatar
Default Re: (temp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">says the man with 12 posts </TD></TR></TABLE>
Who registered 9 months ago
Old Nov 11, 2005 | 03:29 PM
  #4737
temp's Avatar
Default Re: (GrayT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GrayT &raquo;</TD></TR><TR><TD CLASS="quote">
Who registered 9 months ago </TD></TR></TABLE>
lurkers can die
Old Nov 11, 2005 | 03:30 PM
  #4738
adiDAs's Avatar
**crying furiously**
knowledge back me up man LOL
Old Nov 11, 2005 | 03:35 PM
  #4739
theSYNDICATE's Avatar
From: Derek Jeter drinks wine coolers,, The Nation, USA
Default Re: (temp)
lurkers can die </TD></TR></TABLE>
Post ****** unite.
I ordered my pistons last night
I need boost in my life.
Old Nov 11, 2005 | 03:36 PM
  #4740
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adiDAs &raquo;</TD></TR><TR><TD CLASS="quote">**crying furiously**
knowledge back me up man LOL</TD></TR></TABLE>
n00b
Old Nov 11, 2005 | 03:45 PM
  #4741
92LSVTEC's Avatar
Default Re: (RalliartRsX)
a little drama in the DA thread??
well, i had a free afternoon at the body shop, so i painted up a mad JDM valve cover!!
what do you guys think??
Old Nov 11, 2005 | 04:07 PM
  #4742
4NLINE UNLIMITED's Avatar
Default Re: (92LSVTEC)
I Likie Make Me One
Old Nov 11, 2005 | 04:12 PM
  #4743
GrayT's Avatar
Either the picture isn't the best quality or the paint looks ultra 'creamy.'
Old Nov 11, 2005 | 04:49 PM
  #4744
markwitdada9
Guest
Posts: n/a
so sick
Old Nov 11, 2005 | 05:11 PM
  #4745
GrayT's Avatar
Default Re: (markwitdada9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markwitdada9 &raquo;</TD></TR><TR><TD CLASS="quote">so sick</TD></TR></TABLE>
I spy PS, though!
Old Nov 11, 2005 | 06:40 PM
  #4746
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
Default Re: (GrayT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GrayT &raquo;</TD></TR><TR><TD CLASS="quote">I spy PS, though!</TD></TR></TABLE>
yeah rims dont look right.
Old Nov 11, 2005 | 07:23 PM
  #4747
Marble's Avatar
Default Re: (1 point 6)
And not much of a teaser when you show the whole car.
Unless the whole tease is that he/ she really doesn't have red GT3's yet.
Old Nov 11, 2005 | 09:45 PM
  #4748
.Jay's Avatar
Default Re: (Marble)
I would have to agree with this statement. One of the cockiest guys on HT (no offense ) but pull it off with his knowledge.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92LSVTEC &raquo;</TD></TR><TR><TD CLASS="quote">a little drama in the DA thread??
what do you guys think??</TD></TR></TABLE>
How long did it take you? Looks pretty decent.
Old Nov 11, 2005 | 09:56 PM
  #4749
ChaseIntegra's Avatar
Default Re: (.Jay)
I'm stayin out of this argument at this point. This talk needs to be in the all motor forum!
Old Nov 12, 2005 | 03:21 AM
  #4750
jeremy.'s Avatar
Default Re: (ChaseIntegra)
less talking more pics....here is another one of my beater
