DA Integra's Only
Old Apr 12, 2010 | 07:49 PM
  #38251
Colin's Avatar
Default Re: DA Integra's Only
Originally Posted by b6t
They let you run the track w/ your windows up? For me it's always been a rule that the windows are down.
Old Apr 12, 2010 | 07:55 PM
  #38252
hb420's Avatar
Old Apr 12, 2010 | 08:43 PM
  #38253
b16-ef-si's Avatar
1200 hobos----sounds so siiiiiiik
hb420----thanks for the walpaper
Old Apr 12, 2010 | 09:02 PM
  #38254
90IntegraTuner's Avatar
Originally Posted by hb420
O cmon...where in Philly are there trees like that?!?!?! :-P
Old Apr 12, 2010 | 09:35 PM
  #38255
Brice.Hayden's Avatar
for a short stint i had a jdm b16 with an LS trans and i would beat a LS with a b16 LSD setup.
when i had the full b16 swap, i would beat 94-95 GSR's
driver has a decent amount to do with it too
Old Apr 12, 2010 | 10:39 PM
  #38256
teggi's Avatar
i know this is off topic but i got pulled over a few mins ago.
got a fix it ticket for: "modified exaust system" which he reffered to the no name short ram that he also called a "cold air intake" and for the lil hose that runs from the VC to the intake pipe, because it was replaced with one of those lil air filters.
the main reason he pulled me over was because i didnt have my front licence plate.
I was told by him that i got to take the car to the state reff and make an apearance to court.
I know some of u guys have had some sort of similar situation.....
my question is, what should i do or not do at court
thanks in advacen
Old Apr 13, 2010 | 12:08 AM
  #38257
Mattyg2's Avatar
Fix the problems and go to the state ref and get signed off.
Old Apr 13, 2010 | 03:01 AM
  #38258
negusjuda's Avatar
Originally Posted by dblock8989
lmao alot of ppl bashin on the b16's...lol wow they move. as for the b20 (SERIOUS?????) pull them all day. in my obd0 whether its slapped wit a vtec head or not. nd stop actin like use aint never had 1 . Srry i didnt wanna drop 2800 and some change on a GSR lol
lol you pulling on b20vtecs allday in what pls dont say in a b16 or ls i find that very hard to beleive even if the b20vtec is bone stock i still find it hard to beleive
Old Apr 13, 2010 | 04:11 AM
  #38259
Mattb16teg's Avatar
Community Builder
Community Influencer
Herb, where did you take that? Rain Forrest?
Originally Posted by OldSkoolDa91
most b16s are quite boring, especially in a heavy car. i have not been impressed by very many b16s at all. very few and far between. and no, i have never owned on nor do i ever plan to. only way i'd ever own one is if i got it for stupid cheap, put it in a car, and sold the car as soon as it was running to make money.
Eh I'm not gonna knock a B16 as it was my first swap, I liked it. Like anything though, it got old after a while and slow. That's when I threw the jug on it
I got a great deal on mine and couldn't pass it up.
LOL, went 15.0 in it with I/H/E!
Originally Posted by 95-db6-719
rear wheel drive, locked rear end(welded dif) S13 yeah, my friend that owns the S13 says it kinda pulls like it has a LSD, but like you said i dont think it does, doesnt help that my passenger side axle is **** and needs replaced. I was told if you pull the axle and look inside the tranny and there is a bar going across the whole its not LSD, if there is no bar, then it has LSD. or you do the burnout trick, and if both tires hook and burnout evenly then it does.
the likely hood of it being LSD is slim i know, but one can only hope
Yea, take it apart and find out. I don't think the burnout trick will be definitive enough.
Bar Trick:
When my LSD ate my axle I had to take the drivers side out and use a piece of pipe to get the pass side piece out. This is true!
or apparently:
Operational Check
1. Set the parking brake and block the rear wheels.
2. Raise the front of the vehicle, and support it with
safety stands in the proper locations.
3. With the engine off, shift the transmission into 1st
gear.
4. Rotate either front wheel by hand and check that
the other wheel rotates in the opposite direction.
5. lf the opposite front wheel does not rotate, or if vou
cannot spin the front wheels at all, the limited slip
differential is faulty and should be replaced.
Source: 1998-2001 Integra Service Manual
I'm pretty sure he meant just a normal B20.
Old Apr 13, 2010 | 05:51 AM
  #38260
negusjuda's Avatar
nope he clearly says it right here weither its slapped with a vtec head or not lmao and he is supposedly doing this in a b16 now dont get me wrong the lil engine that can a.k.a b16 is nice top end wise but on its best day its not gonna out run a b20vtec lol unless the driver is a absolute moron and cant drive at all but motor to motor a 1.6 vtec is not gonna out run a 2.0 vtec that just sounds crazy saying it lol
Old Apr 13, 2010 | 05:55 AM
  #38261
negusjuda's Avatar
lol and on top of that he said he does it in his obd0 b16 lol dosent that motor have like 158bhp a stock b20vtec is putting down more then that to the wheels
Old Apr 13, 2010 | 06:01 AM
  #38262
Mattb16teg's Avatar
Community Builder
At least you deciphered that message, lol! I just picked out key words and ran with it.
Pretty sure all 1st gen B16's were 160 and all JDM 2nd gens were 170. I know some early model B16s made 150 just not sure what they came in.
Ehhh, your comment about a "stock B20" making more power isn't necessarily true. You could slap a Vtec head on a B20 block and still not make that much power. So many factors come into play its tough to say anyway.
Old Apr 13, 2010 | 06:17 AM
  #38263
projectTeG's Avatar
i find this hard to believe, the amount of power between a LS and a GSR is very noticeable, if anything that set up might hold a against a GSR for a sec or two, the GSR has more horsepower, just plain and simple.
my GSR with a LS trans will rape a LS with a GSR trans, i ll put money on it.
and dont you mean YS1..?
nope small spline y1. and the ls was in a 91 rs teg with weight reduction. shorter gearing plays alot into the equation.
im not saying that the gsr is weak but the ls in its power is a strong engine, to redline it out powers b16s and is comparable to gsr engines. and im also speaking from experience, my ls was also a whole lot faster than the rest of the ls engines i raced i averagely pulled other ls's about 2-3 cars on my shorted geared tranny. hell even with the 4.4 a1 trans i had.
gah it sounds like im back in Hs talking about the ls. now im a vtec happy and ****.
Old Apr 13, 2010 | 06:21 AM
  #38264
projectTeG's Avatar
i like b16s they just dont "feel" quick. they more or less just go haha i have a delsol vtec and its a world of difference from my 1.9l ls/vtec
Old Apr 13, 2010 | 08:16 AM
  #38265
DumaDA's Avatar
ive ridden in a em1 with intake, header, IM+throttle body, and exhaust, **** was still slow, just loud
Old Apr 13, 2010 | 08:41 AM
  #38266
tegman23's Avatar
My old b16 in my da went 11's
Old Apr 13, 2010 | 08:50 AM
  #38267
DumaDA's Avatar
boost doesnt count
Old Apr 13, 2010 | 08:57 AM
  #38268
kNOwLedGe.'s Avatar
Cornering speed > horsepower.
Old Apr 13, 2010 | 09:20 AM
  #38269
Mattb16teg's Avatar
Community Builder
But there are no turns on my race track
Old Apr 13, 2010 | 10:09 AM
  #38270
kNOwLedGe.'s Avatar
Sucks for you.
How far away are you from VIR?
Old Apr 13, 2010 | 11:17 AM
  #38271
Mattb16teg's Avatar
Community Builder
Sucks for you.
5 hours
Old Apr 13, 2010 | 11:38 AM
  #38272
1200 Hobos's Avatar
Make a weekend of it, 5 hours is a lot but still possible. For VIR, it's well worth it. That track is very nice. You just have to bring spares with you so you can make it home if something happens, make sure the car is in tip-top shape mechanically and you're good.
Old Apr 13, 2010 | 11:52 AM
  #38273
Mattb16teg's Avatar
Community Builder
I would like to, just not in this car.
I would have to readjust the suspension and especially the tune! and get some better tires. Maybe other time with another car!
Old Apr 13, 2010 | 01:00 PM
  #38274
negusjuda's Avatar
everything in a em1 if not boosted is slow they so darn heavy lol
Old Apr 13, 2010 | 01:02 PM
  #38275
negusjuda's Avatar
ok i have a question about my rmf replica header now on this header where the 4 pipes come into one pipe isnt the single pipe a lil to small and wouldnt it rob hp
