DA Integra's Only
Old Jan 25, 2010 | 05:31 PM
  #35751
OldSkoolDa91's Avatar
Default Re: DA Integra's Only
once i start getting checks coming in from my new job and get some bills paid off, i want to pick up two of them. one for my da and one for my hatch
Old Jan 25, 2010 | 06:09 PM
  #35752
Mattb16teg's Avatar
Community Builder
Community Influencer
Originally Posted by slammedg2
thinkin about making the DA hydro..... im tired of seeing the cable laying in the bay
Why Hydro, why spend the extra money for almost nothing?
There are so many ways to hide the clutch cable.
Originally Posted by kNOwLedGe.
You could always just route the clutch cable under the intake manifold. You won't be able to see it.
X2, that's what I did.
You must be on PCP.
The long geared YS1 is the longest B-series transmission you can get and the GS-R/RSi/XSi YS1 is near identical to a 96 spec ITR transmission. It's a night and day difference.
The day I got my car back with the XSi swap (w/ short geared YS1), I was in 5th gear cruising on the freeway and kept wanting to shift into what I thought should be 4th gear. 5th gear in a short YS1 feels like 3rd gear in a long YS1.
Oh, it's a big difference.
I wouldn't recommend getting a pre-YS1 B16A transmission. There is absolutely NO WAY to get new replacement parts for them. With a YS1 case (short or long), you can use gearsets from any other B-series transmission and find all of the replacement parts (gears, synchros, countershaft).
Kyle speaks the truth!
Old Jan 25, 2010 | 06:10 PM
  #35753
tegman23's Avatar
Yeah I always see the gsr going for like 350-400...I just bought 2 trannys and resold them..bout a s1 b16 trans for 150 and just resold it...and bought another gsr(b17)and resold that..lol
I wish I lived closer to that guy with the timing belt...I could use some cash hardly have time to work since school....The only thing I would wonder is did he mess somthing up already...I had that happen my friend wanted his timing set I cam over it was way off and all put back together...He said he didnt try to start it...after I set it and it didnt sound right..Finally found he tried to do it himself and tried to start it...a bunch of bent valves..LOL..ended up buying that da for $500 a threw some my old valves in and sold it
Old Jan 25, 2010 | 06:44 PM
  #35754
amaro321's Avatar
Is Anyone Interested In A Good P75 ECU?
Old Jan 25, 2010 | 09:55 PM
  #35755
jasperdeea90's Avatar
[QUOTE=kNOwLedGe.;41021874]Lots of going on in this thread.
you knew THAT was commin...
Old Jan 26, 2010 | 04:06 AM
  #35756
Mattb16teg's Avatar
Community Builder
uhh quoting fail?
Old Jan 26, 2010 | 04:36 AM
  #35757
negusjuda's Avatar
man and i thought i payed to much for my ys1 i paid 450 and it has a obx lsd in it i seen one on here going for 500 the other day thats a bit much to me
Old Jan 26, 2010 | 06:35 AM
  #35758
Mattb16teg's Avatar
Community Builder
I bought my YS1 for $300 a few years back.
Def love my OBX LSD, people knock it but I guess it's just because of their ignorance.....
Old Jan 26, 2010 | 08:57 AM
  #35759
kNOwLedGe.'s Avatar
LOL WUT?
Old Jan 26, 2010 | 09:03 AM
  #35760
90efsedan's Avatar
Hey I just bought a DA and I have a little problem ...when I turn on my heater fan after it rains water drips from the passenger side of the dash like around where the heater core is.....after the heater fan has been on high for a few minutes it stops...has anyone had this problem and can help answer my question? My passenger side carpet gets soaked....thanks
Old Jan 26, 2010 | 09:10 AM
  #35761
da9leo's Avatar
I <3 DA's
Originally Posted by 2ndJenn
1st go to Acura or Honda and order qty 8 of part number 91608-SJ6-003. It is a small white rubber seal. They cost about $ 2.50 each 2nd remove the wiper arms and the wiper motor cowl. The wiper cowl is the long black panel under the wiper arms. Pop out the black circles and unscrew the white clips. You may also have to pull out the plastic pins under the rubber seal on the firewall side of the cowl. The panel is cumbersome. Use caution not to break the ends near the hood hinges. After you remove the cover there is another black cowl on the passenger side. This cowl covers the passenger cabin air intake. The leak is coming from the black plastic push screws that hold that cover on. When you remove the cover you can see the seals in the holes that the push screws were in. The rubber seal dry-rots over time and the sides split open. Water leaks in one drop at a time and adds up quickly. Once you have replaced the seals you should be leak free for another 9-10 years.
hope this helps, this is how i fixed mine
but the price is more like $4.50 each now
Old Jan 26, 2010 | 10:24 AM
  #35762
DumaDA's Avatar
hey do you guys know if a b16 oil pan will fit on my ls? i broke my oil pan yesterday
Thank god i was close to home so the oil didnt leak out until i was already parked for a bit
Old Jan 26, 2010 | 11:44 AM
  #35763
g2_teg_'s Avatar
Originally Posted by Mattyg2
The cable transmission makes the DA what it is. Keep it original!!!
i've had a 91 CRX, 90 hatch, and a DA with 4 different hydro setups in those three cars. Every one of them made me wish i still had a cable trans. Unfortunately the hydro trans that worked the best was a X2M5. They don't make cable K-Series transmissions
Old Jan 26, 2010 | 11:50 AM
  #35764
LOL WUT?
it was simply a response to your quote a while back. I was doin' a marathon read, soo yeeah...new castle+insomnia=horrible attempt at humor,
and i appoligize.
Back to any and all thing da please
Old Jan 26, 2010 | 11:59 AM
  #35765
Mattb16teg's Avatar
Community Builder
Yup, how all of us fixed ours!
But I got mine on the cheaps, check out:
http://www.acuraoemparts.com/delray/...1=&inputstate=
$1.76 each!
Read the write up here on HT or on G2ic. It isn't a hard job to do but it isn't fun and you may break something if you are careless!
Old Jan 26, 2010 | 12:13 PM
  #35766
1Slamdteggy's Avatar
mines does the same thing i dont kno what its is if you ever find out let me kno
Old Jan 26, 2010 | 12:16 PM
  #35767
hey do you guys kno if a b18b1 valve cover work properely on a b18a1?
Old Jan 26, 2010 | 12:24 PM
  #35768
projectTeG's Avatar
yes same pans
Old Jan 26, 2010 | 01:00 PM
  #35769
tougel's Avatar
$300 for a short geared GS-R YS1 isn't right. I would expect to pay double that.
Maybe the economy just sucks that bad.
got my ys1 gsr tranny for $150. a but im selling my b18a1 with a b17 tranny for $700 any one? or trade for a single cam engine with tranny
Old Jan 26, 2010 | 01:02 PM
  #35770
DumaDA's Avatar
Originally Posted by projectTeG
yes same pans
k cool, but i just found out the drain plug on the oil pan is stripped so iono gonna look for an ls oil pan for now
Old Jan 26, 2010 | 01:49 PM
  #35771
e12ikktos's Avatar
foo you can use a piggy back plug
i got one on mt ls pan and im not leakin......
Old Jan 26, 2010 | 01:51 PM
  #35772
DumaDA's Avatar
how much is the plug? im trying to get this **** finished tonight
Old Jan 26, 2010 | 01:53 PM
  #35773
e12ikktos's Avatar
like 3-7 bucks
wheres some da pics up man
thread kinda dieing thats bad lol
Old Jan 26, 2010 | 01:55 PM
  #35774
DumaDA's Avatar
we'll see, you're gonna be home all day? if anything i'll just go home after work grab the tools and go to your house and pull the pan off, then go kragen and buy that **** you were talking about, then get to work
Old Jan 26, 2010 | 02:23 PM
  #35775
nels00n's Avatar
anyone got a oem hood bra w fender pieces for sale?
