DA Integra's Only
Old Mar 30, 2010 | 05:29 AM
  #37826
1ac4u2nv's Avatar
Default Re: DA Integra's Only
Finally got my Teg out. New wheels for 2010, changed the mirrors, wet sanded and buffed. what do you think?
Old Mar 30, 2010 | 05:47 AM
  #37827
Mattb16teg's Avatar
Community Builder
Community Influencer
Car looks good! Take the H emblem off the hood, is the hood painted black?
Are you coming to the Innovative Dyno day Saturday, I see your in PA, where at?
Old Mar 30, 2010 | 05:48 AM
  #37828
hb420's Avatar
Looks really good, are you gonna get some one piece lights?
Old Mar 30, 2010 | 06:32 AM
  #37829
1ac4u2nv's Avatar
hb420 > Thanks man, I want 1 pieces badly. I gotta get my money up though. I think I saw you selling yours at one time.
Mattb16teg > I appreciate it man. I didn't know about the Innovative Dyno day, we shall see. I'm near Allentown (aka sh*thole) The "H" stays for now lol. The car is black down the center.
I have so much more to do. Lower control arms, new struts, upholstery on door panels, wire tuck, turbo etc... Still love DA's
Old Mar 30, 2010 | 06:35 AM
  #37830
hbyrd8701's Avatar
Originally Posted by negusjuda
change the ecu and you should get rid of the oil light if im not mistaken running the vtec ecu its looking for oil pressure to run vtec and the ls motor dosent have it i could be wrong but id say get the pr4 ecu
I hope your right....
Old Mar 30, 2010 | 07:10 AM
  #37831
hbyrd8701's Avatar
anybody else..
Old Mar 30, 2010 | 07:42 AM
  #37832
Mattb16teg's Avatar
Community Builder
Originally Posted by hbyrd8701
anybody else..
^^ sounds about right, whats the issue again?
Old Mar 30, 2010 | 10:09 AM
  #37833
95-db6-719's Avatar
Originally Posted by b16-ef-si
4inch drop on what?
well its at least a 3 inch drop on the DA i have, 14" Z racing wheels, thats what wheels came on the car.
Old Mar 30, 2010 | 10:16 AM
  #37834
92durtyintegraGS's Avatar
Is 450 lb spring rate acceptable for the front, & 350 lb for the back? Thinking that this set up would be good for daily driving?
thanks
JAYP
Old Mar 30, 2010 | 10:21 AM
  #37835
projectTeG's Avatar
im running 650 fronts and 450 rears and its ok on daily, a little stiff but tolerable.
Old Mar 30, 2010 | 10:22 AM
  #37836
DumaDA's Avatar
damn, apparently tracking down 92-93 front bumper lights isnt easy, i dont want to have to buy the amber ones from ebay, i want the oem ones, but no one seems to have them on craigslist.
Old Mar 30, 2010 | 10:41 AM
  #37837
Mattb16teg's Avatar
Community Builder
Uh I should have mine somewhere in my basement. If I can find em, want em?
Old Mar 30, 2010 | 10:47 AM
  #37838
DumaDA's Avatar
im down haha, i've never bought anything from someone offline before though so you'd have to walk me through the process
Old Mar 30, 2010 | 10:57 AM
  #37839
hb420's Avatar
I just sold some 92-93 oem bumper lights for $10 lol
Old Mar 30, 2010 | 11:03 AM
  #37840
DumaDA's Avatar
if only there were more people in my area with da's
Old Mar 30, 2010 | 11:16 AM
  #37841
kNOwLedGe.'s Avatar
I say you take the Mugen emblem off of your replica bumper cover.
Old Mar 30, 2010 | 11:18 AM
  #37842
Mattb16teg's Avatar
Community Builder
REALLY?!?!?! and your in the car game? LoL shocking.
It's not a tough process and everyone knows I'm a stand up feller!
LoL harsh!
Old Mar 30, 2010 | 12:58 PM
  #37843
OldSkoolDa91's Avatar
Originally Posted by 95-db6-719
OK guys so its time to buckle down and get the DA done. I have 60 days to complete a engine swap, fix a intermitin electrical problem, and prep and paint the entire car.
I need a little help though.
First off, my engine swap delema. The b18a that is currently on my rs has seen its life, it has rough starts, the injectors are out of spec. but stills runs. I have a 94 wrecked LS with about 100k less miles and its a strong engine. I am looking to drop this bad boy in the RS.
I want to convert to the obd1 harness, but i have never swapped a honda engine before. and i have a feeling that the engine harness ties into many other harnesses such as the dash harness and the Cooling fan/AC module.
So how i see it i can leave the obd0 harness and ecu and just use the obd0 sensors on the 94 engine, but use the obd1 injectors cutting the old injectors wires and clips out and soldering the obd1 clips and wires on the obd0 harness. Will this work?? or will it throw a code..
thats my main problem at the moment
I am gonna use the block and the head, use the obd0 dizzy, harness, and most of the sensors.
I have to use the obd1 injectors, they are within spec and have alot more life on them.
I am also using the new intake manifold, it is alot cleaner looking than the b18a manifold. This will also relocate the MAP from the firewall to the throttle body.
will this work, has anyone performed this before..?
this is just all theory in my head at the moment.
Also looked into it, and time to bust the tig welder or the mig welder, the beed blaster and the band saw out, gonna make a set of 1 inch extended top hats... so the 4 inch drop isnt so bouncy.
lets see if i can cover everything here lol...
i've used a newer intake manifold in a da. its simple. as for injectors though, you're not gonna want to run the obd1s as they do not use a resistor box like the obd0s...unless you delete the resistor box and change the wiring around. keep it simple and stay with obd0 injectors. you find them easily in a junkyard. like herb said, re-use your stock harness. you'll need to make 2 changes to it... 1-extend wires for map sensor if you use the tb mounted sensor, or just leave that one unplugged and keep the fire wall mounted sensor and 2-extend the wires for your coolant temp sensor since on the b18b it is located on the thermostat housing. further more, no need to switch sensors over at all. all the ones on the obd1 will work just fine.
hope all that helps you. if you have any more questions, just ask
LoL harsh!
i can vouch for matt. i've delt with him before
Old Mar 30, 2010 | 01:12 PM
  #37844
DumaDA's Avatar
yeah i've always either bought my parts brand new or sourced them from somewhere in the bay area, i've pretty much been able to find anything and everything i need from around here
Old Mar 30, 2010 | 01:56 PM
  #37845
hbyrd8701's Avatar
I have a 93 gsr and I swap in a 98 ls motor for the time being. I just started the car today and the oil light come on then faded out alittle then come back on and stay on. Im still using the p61 ecu and I know that i need a pr4. I also took one of the sensor out the b17 and puy it in the b18. threr one plug that hanging behind the motor cause there no (i think) knock sensor on the ls. so why is the light stay on.....
ok for some good news. I hookup the oil pressure gauge and it was about 75psi so my oil pump is good. if that the case why is my oil light comes on then fade alittle then come back on.....
Old Mar 30, 2010 | 02:34 PM
  #37846
95-db6-719's Avatar
alright man thanks, and i plan on extending alot of wires, while everything is out might as well tuck as much as i can right. And i am going to use the MAP on the throttle body, it looks alot cleaner.
Anyone have deleted EGR gayness...? does it throw a CEL...?
Old Mar 30, 2010 | 03:03 PM
  #37847
hbyrd8701's Avatar
^^well I had one, it was a 91. I just didnt hook it up but it was in my 91 civic turbo with a s300 and it didnt throw any cel.....
Old Mar 30, 2010 | 03:12 PM
  #37848
95-db6-719's Avatar
On the stock ECU..? s300 is hondata right..?
Old Mar 30, 2010 | 03:17 PM
  #37849
hbyrd8701's Avatar
s300 is hondata but when I put that motor in it didnt throw that code....
Old Mar 30, 2010 | 04:00 PM
  #37850
1ac4u2nv's Avatar
LOL!
