___||SOHC Squad||___
Old Dec 3, 2009 | 01:03 PM
  #426
lethal_si's Avatar
Default Re: ___||SOHC Squad||___
Old Dec 3, 2009 | 01:17 PM
  #427
JDMPR's Avatar
I need some fogs like that
Old Dec 3, 2009 | 01:19 PM
  #428
lethal_si's Avatar
kragens!!! haha they look legit huh
Old Dec 3, 2009 | 01:23 PM
  #429
JDMPR's Avatar
Where you buy them at? Advance? Autozone?
Old Dec 3, 2009 | 01:29 PM
  #430
4g4dcruisin's Avatar
Once I get my performance struts and rear camber kit, my **** gonna look just like yours mitsubishiv5!
haha what are performance struts? maybe we should actually talk about some tech in here...
whats ur budget for suspension?
Old Dec 3, 2009 | 01:32 PM
  #431
walmart has some with a yellow reflector in them for $20, they use h4 bulbs. get some yellow h4 bulbs and ur good to go!
  #432
JDMPR's Avatar
I had Tokico illuminas on my DA but I didnt like them much so this time around ima get KYB AGX's since my buddy has them on his coupe and they ride so smooth
Old Dec 3, 2009 | 01:33 PM
  #433
gotcha, what about for springs? lowering springs or coil overs?
Old Dec 3, 2009 | 01:34 PM
  #434
fre's Avatar
fre
Get some Full Coilovers
Old Dec 3, 2009 | 01:38 PM
  #435
ill start the trend, go koni yellows with ground control coil overs!!!!!!!!!!!!!!!!!!
talk about overpriced struts!
Old Dec 3, 2009 | 01:41 PM
  #436
89s1's Avatar
Originally Posted by 4g4dcruisin
because it only started like a week ago!! we're getting a lot of visits tho.
lol, well ****.
Count me in boys.
Here is nice shot of under my hood. Makes me wish I had cleaned that nasty, greasy washer though
  #437
fre's Avatar
fre
It's Performance Struts. Get it RIGHT!!! lol
Old Dec 3, 2009 | 01:46 PM
  #438
JDMPR's Avatar
Shut up you know what I mean, when I get my taxes im thinking about getting the cheapest full coilovers I can find, or Ima get KYB AGX's with Omni coilovers
Old Dec 3, 2009 | 01:49 PM
  #439
EJ6-2nr's Avatar
crappy pics and i've just been messin round with it but heres some updated pics, and yes i kno, i need a mini me
Old Dec 3, 2009 | 02:01 PM
  #440
just get your agx's with skunk2 coil over sleeves. that way you'll be fully right heigth adjustable with a fairly decent ride.
Old Dec 3, 2009 | 02:02 PM
  #441
i dont know if i posted this.
Old Dec 3, 2009 | 02:04 PM
  #442
JDMPR's Avatar
Bro you got camber kits on your 4d? Cause that thing is low! Do you go through tires often?
Old Dec 3, 2009 | 02:15 PM
  #443
nope, no need for a camber kit on 88-00 civics...we dont have factory camber adjustability in the first place. as long as you make sure you have toe set at 0 degrees then you'll be good.
read this
YOU DO NOT NEED CAMBER KITS
i have a brand new set of falken tires that i've been driving on for a couple weeks now and i have SOME inner wear on the treads but i think the toe adjustment is a little off.
Old Dec 3, 2009 | 03:08 PM
  #444
JDMPR's Avatar
Well if thats true then I need to replace all my bushings and tie rods lol
Old Dec 3, 2009 | 03:09 PM
  #445
fre's Avatar
fre
I had to do it....
Old Dec 3, 2009 | 03:16 PM
  #446
outter tie rod ends from autozone are $30 and come with the ball joint. get an Energy Suspension Bushing kit and you'll be good to go. those kits can get expensive but not if you know what to look for...
-LCA bushings
-UCA bushings
-sway bar bushings
those are the primary things. if you replace all ball joints, and bushings, and dust covers...you'll basically have brand new handling. well assuming you re-grease the parts you've replaced the dust covers from.
here if you want to get serious about it Energy Suspension Master Set
Old Dec 3, 2009 | 03:32 PM
  #447
matt j's Avatar
Is your car a dd mattj? Cause if it is it probably wouldnt be a good idea to have itb's, I heard that they hate low rpm's.
no my car is not a DD anymore, its had 166k on the body for about a year now hahaha. i never drive the car really anymore except on nice days.
Old Dec 3, 2009 | 03:34 PM
  #448
so what do you roll in?
Old Dec 3, 2009 | 03:41 PM
  #449
prelude182's Avatar
why? its not like a showroom floor corvette
Old Dec 3, 2009 | 04:09 PM
  #450
JDMPR's Avatar
Now if you were rolling in a Type R then I would see only driving it on weekends or when the weather is nice
