your opinion about a turbo
Old 05-22-2004, 08:00 AM
goose21's Avatar
Default your opinion about a turbo
I have a build b16 9.5:1 and i want to go to the 350+ whp. So today i wanted to order a turbo kit for this. So i went to my tuning shop and i told the guy i want a turbo just for drag racing. I dont need power in low rpm's. So he made a call and said i should go for a t3/t4 with a custum made 69 trim. What do you guys think of a turbo like this.?
Old 05-22-2004, 10:37 AM
goose21's Avatar
Default Re: your opinion about a turbo (goose21)
bump
Old 05-22-2004, 10:38 AM
94gsr4dr's Avatar
for that power there is no need for a custom turbo, most off the shelve T3/T0e's will make enough for you.
Old 05-22-2004, 11:08 AM
goose21's Avatar
Default Re: your opinion about a turbo (94gsr4dr)
And how far can i boost a build b16 with 9.5:1 this is the block
b16 9.5:1
IB Spec Wiseco Pistons
Probe Rods
Bore, Hone, Hot tank, Deck (if nec)
Balanced Crank
Polished Crank
All new Bearings & Thrusts
All new seals, and Oil pan Gasket
New VTEC oil pump
New VTEC water pump
550cc injectors
hondata s200b
What hp numbers should be safe to run with good tuning
Old 05-22-2004, 11:28 AM
94gsr4dr's Avatar
Stock sleeves?
Old 05-22-2004, 12:04 PM
goose21's Avatar
yes the stock sleeves are bored and honed to a 81mm
i would have liked it resleeved but i didn't had the money.
Old 05-22-2004, 12:11 PM
Ben Huynh's Avatar
For your HP goals, a hybrid 69 trim will be a little overkill. You want to look for turbo that compromises between max power and quick spool up.
Old 05-22-2004, 12:12 PM
94gsr4dr's Avatar
Default Re: your opinion about a turbo (ben@importparts.com)
honestly a 50trim .63 ar t3/t0e might be your best bet. http://www.cheapturbo.com has them for 550US
Old 05-22-2004, 12:33 PM
goose21's Avatar
and just one more qeustion. Wil it be better to rev higher. I have a type r head, but should i put in other valve springs and retainers in it to rev higher or wil 8500 rpm be good enough?
Old 05-22-2004, 01:49 PM
goose21's Avatar
bump
Old 05-22-2004, 02:15 PM
boostedbastard's Avatar
You should check out cheapturbos.com
They are offering their peak boost turbo kit again. They also supply you with paper work on different applications so you know what to expect. Not to mention it comes with a lovefab manifold, and lovefab downpipe. If i had to buy a turbo kit it would be this one. Good luck.
Old 05-22-2004, 05:14 PM
94gsr4dr's Avatar
Default Re: your opinion about a turbo (boostedbastard)
I have the cheapturbo kit, it is NOT a lovefab manifold to my understanding. Similar design, but my manifold is different then every lovefab i have seen.
Old 05-22-2004, 05:18 PM
B*A*N*N*E*D
PeakBoost's Avatar
i would also recommend the t3/to4e 50 trim w/ .63 a/r for your application and power goals.
edit: to clear up any confusion. our Peakboost manifold is manufactured in house.
Old 05-22-2004, 06:21 PM
Default Re: your opinion about a turbo (CHEAPTURBOdotCOM)
good to know. I would be interested in purchasing a manifold. What is the cost.
Old 05-22-2004, 06:38 PM
94gsr4dr's Avatar
800
CRXherbie91
11-18-2016 11:34 AM
xchipx
03-13-2010 06:55 PM
kasso
08-25-2005 09:22 PM
mrx
04-29-2005 08:34 AM
Quick Reply: your opinion about a turbo
