AFC Hack with Missing Link
Old Aug 5, 2002 | 11:41 PM
Turbo_Si's Avatar
Default AFC Hack with Missing Link
What exactly happens when u mix the two? will u be able to boost higher? how about idle? what are the pros and cons, has anyone ever tried this before? this is with 440 and inline pump.
Old Aug 6, 2002 | 06:40 AM
turbosol's Avatar
Default Re: AFC Hack with Missing Link (Turbo_Si)
The hack won't work if you limit your MAP sensor, you have to run it with out the missinng link. If you run the missing link you need to run a fmu.
Old Aug 6, 2002 | 08:59 AM
BoostedSi's Avatar
Default Re: AFC Hack with Missing Link (turbosol)
So then if i run a missing link + afc hack on 440s w/ 4:1 fmu. Would it be able to hold about 350whp? thanks
Old Aug 6, 2002 | 09:52 AM
Smashback's Avatar
Default Re: AFC Hack with Missing Link (BoostedSi)
If you're running like that then it's not much of a hack anymore, that's the standard way to run it. If you're putting down 350 then you need to get a real fuel setup before you blow your **** to high heaven.
Old Aug 6, 2002 | 10:53 AM
revhardsi's Avatar
Default Re: AFC Hack with Missing Link (mplex2000)
yeah, u crazy!
Old Aug 6, 2002 | 04:23 PM
Turbo_Si's Avatar
will the 440s with inline pump and VAFC, WITHOUT FMU, be enough for 250-300whp?
What exactly happens when u use the missing link? isn't it like doing the same thing as the hack? it doesn't allow the map to see boost?
Old Aug 6, 2002 | 07:50 PM
Turbo_Si's Avatar
is the vafc hack really better than the standard FMU with VAFC setup?
Old Aug 6, 2002 | 08:16 PM
98civicEX's Avatar
yes!!
Old Aug 7, 2002 | 03:02 PM
filetofit
Guest
Posts: n/a
Default Re: AFC Hack with Missing Link (98civicEX)
Uh you're missing the point of the hack. You can't use a missing link because the missing link doesn't let you're stock MAP sensor see boost and with the hack you want the MAP sensor to see full boost up to 11 psi. The VAFC then takes that MAP sensor output signal and knocks it down by about 45%, so that 5 volts MAP sensor output becomes 3 volts input to the ECU, which won't throw a CEL.
Old Aug 7, 2002 | 04:47 PM
Turbo_Si's Avatar
Default Re: AFC Hack with Missing Link (filetofit)
can i use inline pump with the hack?
Old Aug 8, 2002 | 11:59 AM
PolySquared's Avatar
keep going. i'm learning.
Old Aug 8, 2002 | 12:24 PM
filetofit
Guest
Posts: n/a
Default Re: AFC Hack with Missing Link (PolySquared)
Let's take an example. Let's say you're engine is turning at 5000 rpm's. Inside the ECU is a lookup table. The ECU takes the MAP sensor voltage and looks up a value of injector pulsewidth for this RPM. So if you are cruising, let's say the MAP sensor output is 1.6 volts. The ECU says "hmmm... 5000 rpm, 1.6 volts, that corresponds to about 16 inches of manifold vacuum. That means I should tell the injectors to open for 5 milliseconds." But if you were getting on it, in an NA car, at 5000 rpm, your MAP sensor would be putting out about 3 volts. The ECU says "hmmm... 5000 rpm, 3.0 volts, that corresponds to about zero inches of manifold vacuum. That means I should tell the injectors to open for 10 milliseconds." Now here comes Joe Riceboy and he throws a turbo, a VAFC, and 450cc injectors on his car. The ECU doesn't know this of course. Now, same scenario, except while cruising, the VAFC intercepts the MAP sensor signal and turns it from 1.6 volts into 1 volt and sends the altered signal to the ECU. The ECU says "hmmm... 5000 rpm, 1.0 volts, that corresponds to about 20 inches of manifold vacuum. That means I should tell the injectors to open for 2.5 milliseconds." However these are larger injectors so even though they are open for a shorter time, they flow more fuel, and since total fuel delivered = rate x time the total amount of fuel delivered remains the same (remember this is cruising). Now you punch it, spool up the turbo and you're at 5000 rpm. You're boosting 11 psi. The MAP sensor is putting out 5 volts. This would normally throw a check engine light. However the VAFC intercepts it, and turns it from 5 volts into 3 volts. The ECU says "hmmm... 5000 rpm, 3.0 volts, that corresponds to about zero inches of manifold vacuum. That means I should tell the injectors to open for 10 milliseconds." These are big injectors though so you are sending way more fuel to the engine now, which is what you want under boost.
Capiche?
Old Aug 13, 2002 | 07:28 AM
X2BOARD's Avatar
Thank you for that simply worded, easy to understand overview !
X2
Old Aug 13, 2002 | 08:18 AM
Finest's Avatar
Default Re: AFC Hack with Missing Link (X2BOARD)
LOL!
AFC HACK for Dummies.
Old Aug 13, 2002 | 08:43 AM
filetofit
Guest
Posts: n/a
X2
Don't be afraid to think!
Old Aug 13, 2002 | 08:44 AM
X2BOARD's Avatar
Funny... last time I thought, some gas came out of my ear !
Old Aug 13, 2002 | 09:17 AM
filetofit
Guest
Posts: n/a
Same thing happens to me... it's burning oil, like everything else
MickeeFREE
Apr 14, 2005 09:36 PM
soulrider4ever
Feb 21, 2004 11:00 AM
soulrider4ever
Feb 20, 2004 01:15 PM
2muchPSI
Nov 18, 2003 01:03 PM
DLOTYPER
Jun 2, 2003 12:19 PM
