Reading mmHg and translating it to PSI
Old 04-14-2005, 07:32 PM
MickeeFREE's Avatar
Default Reading mmHg and translating it to PSI
okay i know that
760mmHg=1atm=14.7psi
so i have a vafc and i run the pressure channel and at idle it runs about ~ -550mmHg
and when flooring it it goes to 0mmHg
the car is supposeldly pushing 5psi i jes wanted to be sure...
so is there soemthing wrong that the vafc is reading 0mmHg
would teh culprit be missing link?
any help would be appreciated.. thanks
5psi = ~260mmHg
Old 04-14-2005, 07:42 PM
Who is Mr Robot?
wantboost's Avatar
Default Re: Reading mmHg and translating it to PSI (MickeeAgain)
yea, you dont need a missing link AND a vafc, take off the missing link
Old 04-14-2005, 07:45 PM
MickeeFREE's Avatar
Default Re: Reading mmHg and translating it to PSI (wantboost)
im not running the hack....
Old 04-14-2005, 07:47 PM
Who is Mr Robot?
wantboost's Avatar
regardless, the missing link keeps the map sensor from seeing booost, so it will read 0mmHg on the vafc...
just take the missing link off, the car should run better and it will read boost
Old 04-14-2005, 07:48 PM
93turbo16's Avatar
you are running the hack if you have a vafc on there. The missing link keeps it from seeing boost, like stated above... if it did you would throw a check engine light.
Old 04-14-2005, 07:55 PM
MickeeFREE's Avatar
Default Re: (93turbo16)
I am not using the vafc for any fuel stuff....
im actually running off a vortech fmu ( yeah i know... jes saving up for s200 w/ boost)
so i guess i was right.. it was the missing link....
ill try something tonite...
thanks fellas...
so if i take out the missing link.. it will work fine? and i wont get a asthametic idle.. (fluctuating up n down?)
thanks
Old 04-14-2005, 07:58 PM
Who is Mr Robot?
wantboost's Avatar
Default Re: (MickeeAgain)
, if the vafc read boost it would throw a check engine because without correction it will still send that same voltage to the ecu.
you need to turn the vafc down far enough for it to cut the signal down so it doesn't read the same voltage
Old 04-14-2005, 08:11 PM
MickeeFREE's Avatar
Default Re: (wantboost)
and how do i do that?...
thanks in advance
Old 04-14-2005, 08:12 PM
93turbo16's Avatar
just keep it in for now, untill you get real managemenet. What injectors are you using?
Who is Mr Robot?
wantboost's Avatar
i dont remember exactly, havent looked at one in ages, lol
Old 04-14-2005, 08:14 PM
93turbo16's Avatar
if you are using 450 injectors then knock it down to like -40 or so across the board. If you are still running 310s, keep the missing link on there. You won't be able to lean it out enough.
MickeeFREE's Avatar
everything is stock...
jes have vortech FMU.... inline bosch pump....
Old 04-14-2005, 09:22 PM
Finland's Avatar
mmHg (millimeters of mercury) is used for measuring absolute pressure (vacuum), so generally you won't see anyone trying to convert mmHg to show positive pressure (psig). You can easily convert it to Psia though. The VAFC will show KGcm2 on boost if you ever get rid of the missing link.
Modified by Boondock Saint at 1:35 AM 4/15/2005
Old 04-14-2005, 09:36 PM
MickeeFREE's Avatar
Default Re: (Boondock Saint)
hmmm i see.... so even if i dont use the missing link when proper fuel management i will never see positive mmHg...? and translate it to psi..
hmm thats pretty weird...i guess i jes have to wait until i install teh s200 w/boost or atleast find someone who does
tahnsk everyone...
spotscivic
12-14-2007 10:43 PM
soulrider4ever
02-21-2004 11:00 AM
2muchPSI
11-18-2003 01:03 PM
ReeH!
10-02-2003 08:16 PM
Turbo_Si
08-13-2002 09:17 AM
Quick Reply: Reading mmHg and translating it to PSI
