would this setup be good for 300hp
Old Jun 28, 2003 | 07:25 PM
Black DC2's Avatar
Default would this setup be good for 300hp
okay here is my setup i'm hoping to get near 300
98 GS-R
turbo drag 3 spec r t3/t04e .57 trim compressor with .60 a/r, turbine is a .63 a/r
9-8-1 JE .20 over eagle rods GE block guard
build head valves,guides,retainers and springs(ferrea valves)
engine management
550 lucas injectors and s200 hondata with 3 bar map
going to boost at max 14 psi u guys think i'll be near 300 with this setup and how much u guys think i can boost.
JOHN AT secret servives is doing all the tuning
Old Jun 29, 2003 | 06:19 AM
Black DC2's Avatar
Default Re: would this setup be good for 300hp (Black DC2)
anyone
Old Jun 29, 2003 | 06:22 AM
PLRacer's Avatar
it think ull get more than 300 at 14 psi. like 350 maybe.
Old Jun 29, 2003 | 08:46 AM
Quick 200k Mile Motor's Avatar
build head ..did you also mean worked valve seats & port?
I'll estimatewith mild port & 3 angle at 14psi:
330hp
235ft-lbs
Old Jun 29, 2003 | 10:12 AM
Black DC2's Avatar
Default Re: would this setup be good for 300hp (Quick 200k Mile Motor)
NO port and polish just valve springs ECT...
Old Jun 29, 2003 | 12:08 PM
quikB18B's Avatar
I say your getting ahead of ourself your focusing so much on the head right now focus more on putting your $ better toward a good setup that compliments each other well. If u have the right setup i see you closer to 400 with 14 psi, look into getting the precision sc61 great street turbo if you want to make good power. There have been many success stories on this turbo.
Do a search and look more into these people's setup and it well help to better guide you. Hope this helps
Old Jun 29, 2003 | 12:10 PM
quikB18B's Avatar
Default Re: would this setup be good for 300hp (quikB18B)
https://honda-tech.com/zerothread?id=532800
here this should be a start
Old Jun 29, 2003 | 12:11 PM
done's Avatar
ive seen 311hp (stock 10.0) compression at 10.5 psi.. soo yeah i think you can hit that goal easily
WH0R3nEF9
Nov 3, 2005 05:09 PM
9K RDLNE
Oct 17, 2005 12:41 PM
Pfieff
Apr 1, 2004 03:36 PM
gsrpower95
Aug 6, 2003 07:08 AM
Red99CivicSi
Oct 3, 2002 02:45 PM
