would this effect my boost gauge readings??
Old Jun 10, 2004 | 09:01 PM
blackeg's Avatar
Default would this effect my boost gauge readings??
well the autometer gauge came with 1/8 nylon hose, but to to lack of fittings, i switched it over to 1/4 inch instead. would the increase in diameter make a difference in what the gauge read?, cause right now its reading like 10 vaccum at idle, and i dont think thats right
Old Jun 10, 2004 | 09:21 PM
VacantBanana's Avatar
Default Re: would this effect my boost gauge readings?? (blackeg)
mine reads 15, u should be ok, where did u make the transistion from 1/8 to 1/4?
Old Jun 10, 2004 | 09:22 PM
Default Re: would this effect my boost gauge readings?? (VacantBanana)
or should i say it did bc it got stolen today
Old Jun 10, 2004 | 09:32 PM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VacantBanana &raquo;</TD></TR><TR><TD CLASS="quote">or should i say it did bc it got stolen today</TD></TR></TABLE>
sucks man- damn people and their stealing
well i have a 1/4 nylon goin right to the back of the boost gauge, and then i have it transition to a 1/8 vacuum hose about a foot from where its T'd into the fpr vacuum hose
Old Jun 10, 2004 | 09:44 PM
just buy the 1/8 fitting, i think its stock #1551 ???? its like 5$ for the fittings and the nylon
Old Jun 11, 2004 | 06:29 AM
blackeg's Avatar
hmmmm....
Old Jun 11, 2004 | 06:51 AM
DaX's Avatar
DaX
Loved
Community Favorite
It shouldn't make a difference, unless the line is collapsing under vacuum. I'm going to be using 1/4 ID fuel hose for ALL my vacuum/boost lines on my setup.
Old Jun 11, 2004 | 06:56 AM
PM-Performance's Avatar
Default Re: (DaX)
im actually not sure, but that might make sense for mine . mine always reads about 2psi more than it should. i ditched the nylon line and ran like 4mm vac line tot he gauge.
Old Jun 11, 2004 | 11:22 PM
blackeg's Avatar
Default Re: (itr206)
ok real whacked-&gt; my boost gauge is hooked up, it lights up and ****, it currently wont read vacuum, but i was boosting at a solid 8psi on a 5.8 psi wastegate spring according to the gauge......
Old Jun 12, 2004 | 05:56 AM
DaX's Avatar
DaX
Loved
Community Favorite
Have you dropped your gauge? Sounds like you need a new one.
Old Jun 12, 2004 | 08:07 AM
blackeg's Avatar
Default Re: (DaX)
i personally never dropped it. i got it from a friend who had it lying around his room
Old Jun 17, 2004 | 06:46 AM
blackeg's Avatar
Default Re: (blackeg)
well turns out that on the back of the gauge, one of the 2 brass bolts is loose, and it falls into the gauge sometimes. when this happens im assuming it hits something mechanical, cause the gauge wont read vacuum, just boost. also, when the car is off, the needle sits at like 1-1.5 in the boost column and not on 0. does anyone know how to adjust where the needle sits when the gauge isnt on?
vladd
Nov 23, 2006 05:46 PM
R6E6I6D
Nov 21, 2005 06:47 PM
bennyhonda7
Jun 7, 2005 01:19 PM
ViruSi
Nov 18, 2004 07:47 PM
LOwrestling2001
May 19, 2002 09:35 PM
