Boost gauge only reading VAC>>???
Old Nov 17, 2005 | 09:07 PM
R6E6I6D's Avatar
Default Boost gauge only reading VAC>>???
Yes I have a turbo, I was figiting with the line going to the boost gauge to install a new light and something happend I cant hear any leaks, and when under boost the gauge reads zero or a little under??? any one ever experience this??
Old Nov 17, 2005 | 09:15 PM
EVIL Hx Coupe's Avatar
Default Re: Boost gauge only reading VAC>>??? (R6E6I6D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R6E6I6D &raquo;</TD></TR><TR><TD CLASS="quote">Yes I have a turbo, I was figiting with the line going to the boost gauge to install a new light and something happend I cant hear any leaks, and when under boost the gauge reads zero or a little under??? any one ever experience this?? </TD></TR></TABLE>
Maybe there's a kink somewhere? The line on my autometer gauge is made of some plastic crap that kinks really easily under the dash.
Old Nov 17, 2005 | 09:32 PM
R6E6I6D's Avatar
Default Re: Boost gauge only reading VAC>>??? (EVIL Hx Coupe)
i think i overtightend the fittings cause the stupid plastic line comes out on a angle and is not right looking like the other one...? i got a good idea tho If i were to take a 1 inch piece of rubber hose and slide it over the nylon boost gauge tube zip tie it on, than tear out the ferral fittings and hook up a 1/8" npt pipe fitting on the boost gauge in its place finally hooking up other end of rubber hose??? ( to minimize ballooning and closing under vac??)
Old Nov 17, 2005 | 09:54 PM
R6E6I6D's Avatar
help
Old Nov 20, 2005 | 08:31 AM
R6E6I6D's Avatar
hrm anyone else?
Old Nov 20, 2005 | 09:13 AM
siekturbo's Avatar
try usiN just the rubber hose instead of the nylon. i had the same prob when there were different kinds of lines. T connectors could also be the problem: check if they're clogged or use a different line from the mani.
Old Nov 20, 2005 | 09:18 AM
R6E6I6D's Avatar
Default Re: Boost gauge only reading VAC>>??? (siekturbo)
really you think teh likes could be messed up maybe ill just Tee it temporarly to test it out cause the vac manifold seems like itd be a good source of boost/vac considering monster brake booster line connectd to it....
Old Nov 20, 2005 | 10:36 AM
Soccerking3000's Avatar
run nice silicon hose from the vacuum manifold and then just push the nylon mini tube into it and use a few zipties to hold it there, thats what i did and it works awesome. You dont have to worry about it kinking then and you can use like a 1 foot section of that stuff that comes with the guage
Old Nov 20, 2005 | 12:00 PM
R6E6I6D's Avatar
Default Re: Boost gauge only reading VAC>>??? (Soccerking3000)
did u experience a problem before this.. well i kinda meesed up one of the ferrals soo i threaded a silicone hose onto the fittin in back of the gauge, ill try to use the old vaccum hose trick... where did u get silicon hose and how much u think it would cost??
Old Nov 20, 2005 | 12:27 PM
yea i had a kink in mine and i was sick of it, i got the silicon hose forlike 40 cents a foot, its really cheap, works great now
Old Nov 20, 2005 | 10:16 PM
R6E6I6D's Avatar
can u get it at a hardware store or auto store?? cause im gunna test my gauge with a bike pump b4 i buy he new one i bought of some expletive on ebay and got rippped!
Old Nov 21, 2005 | 09:54 AM
yea any autostore/hardware store will have the tubing
Old Nov 21, 2005 | 06:47 PM
R6E6I6D's Avatar
its weird, I couldnt find anykinks. when i become unlazy m gunna use some vac line i got laying around and just run in out the window for a test run... and if its a go that the rubberline is what Ill be using.. o and did u jsut get a female 1/8" npt fitting fort the back of the boost gauge to hook up the silicone line??
roni_xxp
Engine Management and Tuning
Mar 26, 2009 09:37 AM
LOwrestling2001
May 19, 2002 09:35 PM
Duck Sauce
Nov 15, 2001 05:36 PM
falcongsr
Jul 3, 2001 03:14 PM
