will it make it to 400whp
Old Feb 22, 2008 | 10:28 PM
ACrite3404's Avatar
Default will it make it to 400whp
ok me and a friend are building his LSv turbo and he want 400whp, i think he will make it tell what u guys think.
Ls bottom-end
eagle rods
arias 9:1
itr oil pump
GSR head
Skunk 2 valvetrain springs, retainer, and valves,
stock gsr cams might be upgrading to Itr's
blox im
65mm professional products throttle body
RC 550's
Turbo Set-up
SLS shorty manifold
Precision SC34
3" dp with Qtp cut-out
tial 38mm WG
No Name FMIC
Blitz type rs
Tuned on Crome
he plans on max boost at 17lbs
lmk what u think
Old Feb 22, 2008 | 11:07 PM
ghostskinner's Avatar
Default Re: will it make it to 400whp (ACrite3404)
going to need bigger injectors at least 680 cc
Old Feb 22, 2008 | 11:20 PM
ACrite3404's Avatar
Default Re: will it make it to 400whp (ghostskinner)
y bigger?
Old Feb 23, 2008 | 12:49 AM
mn_babyboy's Avatar
Then you will be maxing out the injectors. That it can lead to major problems. Go with 1000cc and go for e85.
Old Feb 23, 2008 | 03:58 AM
turbociv910's Avatar
Default Re: (mn_babyboy)
550s are too small thats why
Old Feb 23, 2008 | 07:22 AM
vtec_killer_'s Avatar
Default Re: (turbociv910)
u forgot to mention if u are gonna be street or track?
Old Feb 23, 2008 | 07:30 AM
ACrite3404's Avatar
Default Re: (vtec_killer_)
he is gonna be street
Old Feb 23, 2008 | 10:11 AM
Ekb18c5_BR's Avatar
Default Re: (ACrite3404)
550s are good for 450hp
Old Feb 23, 2008 | 10:27 AM
Schister66's Avatar
Man U FTW
Default Re: (Ekb18c5_BR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ekb18c5_BR &raquo;</TD></TR><TR><TD CLASS="quote">550s are good for 450hp </TD></TR></TABLE>
Yeah good luck with that...he's going to need larger injectors to get to his goals. The 550s might hold out for him, but are going to be damn close to their max. The rule for injector sizing is 6cc of injector per whp.
550cc X 4inj = 2200cc
2200cc / 6cc(per whp) = 367whp with a 75-85% duty cycle
In order to make 450whp with them, they'd be well over 100% duty...
Old Feb 23, 2008 | 10:51 AM
mn_babyboy's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">
In order to make 450whp with them, they'd be well over 100% duty...</TD></TR></TABLE>
dsm 440cc is only good till around 300whp. So if it's another 110cc added... I don't think it will even reach 400whp. Check out Evans-tuning.com. he has a check list for boost.
http://www.evans-tuning.com/te....html
You are going to need at least 750cc to push 400whp. I say go for 1000cc and E85, if your local town sells e85.
e85 is about 105 octane which mean more octane, more power, more boost, more safety.
It wouldn't hurt to spend another 200 to 300 on bigger injector, than try to risk thousands of dollar on blown motor because of small injectors. If he wants to run the 550cc, then just shoot for mid 300whp.
Modified by mn_babyboy at 12:04 PM 2/23/2008
Modified by mn_babyboy at 12:05 PM 2/23/2008
Old Feb 23, 2008 | 11:00 AM
mn_babyboy's Avatar
Also how big is the intercooler??? Cheap brands and small intercooler wont hold a lot of power.
Old Feb 23, 2008 | 12:49 PM
ACrite3404's Avatar
the intercooler ill get the measurements later today
Old Feb 23, 2008 | 01:52 PM
ACrite3404's Avatar
l x w x h
31x3x9
and he wants 400whp not 450whp
Old Feb 23, 2008 | 02:14 PM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mn_babyboy &raquo;</TD></TR><TR><TD CLASS="quote"> I say go for 1000cc and E85, if your local town sells e85.
e85 is about <u>107</u> octane which mean more octane, more power, more boost, more safety. </TD></TR></TABLE>
I'm doing the same...its great to have E85 readily available in our area. By the way, check the bolded area in your quote.
Old Feb 23, 2008 | 02:29 PM
stewie8apie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mn_babyboy &raquo;</TD></TR><TR><TD CLASS="quote">Then you will be maxing out the injectors. That it can lead to major problems. Go with 1000cc and go for e85. </TD></TR></TABLE>
+1
If you can get e85 easily, there is almost no reason for you to get some 1000's and tune it on e85. Just make sure your tuner is familiar with it.
Either way though, you will need bigger injectors.
Old Feb 23, 2008 | 03:55 PM
TIGboy's Avatar
Default Re: (stewie8apie)
either get 1000cc's for E85 or 850's for pump..I suggest going with E85 if you can get a hold of it.
Old Feb 23, 2008 | 03:58 PM
mn_babyboy's Avatar
I'm doing the same...its great to have E85 readily available in our area. By the way, check the bolded area in your quote. </TD></TR></TABLE>
107.. Even better. I put 105 because I read this old thread on E85 and some local tuner said it was about 105 octane as well.
Modified by mn_babyboy at 5:20 PM 2/23/2008
Old Feb 23, 2008 | 04:36 PM
blinx9900's Avatar
rpm plays a roll in injectors ability to make power, if your spinning to 9000rpm 550's probably wont cut it... every setup is different, 550's might make it if you dont spin that high but its your choice everybody here has spoken and we all have experience... i vote for 750's since you'll have room to grow.
judd_123
Nov 23, 2010 04:45 PM
lakai_19
Oct 18, 2010 07:53 PM
EL TYPE R
Apr 11, 2009 08:09 AM
95 civic turbo_gsr
Jul 27, 2008 08:33 PM
high boosted rex
Nov 30, 2005 10:35 AM
