600whp goal
Going for 600whp (for now)
i would like to know if people think i can get to that goal with the setup i have now or if things will need to be changed.
thanks
head
b16
edelbrock intake manifold
skunk2 68mm throttle body
skunk2 springs an retainers
ferriea flattop valves
stock ports
crower turbo cams
toda cam gears
block
golden eagle sleeved ls block
cp 9.1 comp pistons
either eagle rods or manley turbo toughs (dippends on how much money i will have left)
acl bearings
balanced stock ls crank
neuiken t4 topmount manifold
3-4 downpipe
3" full exhuast (might go 4" all the way back)
presicion 6765 billet turbo
tial 44 wastegate
1000cc injectors
walbro feeding a bosch 044
aeromotive FPR
stock gsr trans with a type r lsd
comp stage 5 unsprung clutch
fidenza flywheel
thanks
head
b16
stock ports
crower turbo cams
toda cam gears
block
cp 9.1 comp pistons
acl bearings
3-4 downpipe
tial 44 wastegate
1000cc injectors
aeromotive FPR
fidenza flywheel
If this is going to be more of a track car than street I would get higher compression pistons like a 9:7:1 or higher. Honda engine tunning has come a long way you dont need to run such low compression. If you thinking you want to do this on pump gas and street drive it all the time, think again. I had the same menality when I built mine I ended up runing race gas and only really useing my car at the track. Also I would look into some differient cams. I have also read on here alott that the skunk2 throttle bodys stick everyonce in a while.
thanks
head
b16
stock ports
crower turbo cams
toda cam gears
block
cp 9.1 comp pistons
acl bearings
3-4 downpipe
tial 44 wastegate
1000cc injectors
aeromotive FPR
fidenza flywheel
thanks
head
b16
stock ports
crower turbo cams
toda cam gears
block
cp 9.1 comp pistons
acl bearings
3-4 downpipe
tial 44 wastegate
1000cc injectors
aeromotive FPR
fidenza flywheel
i agree but my post also says 600whp (for now) so i bought somthing that i wouldnt need to change when i decide to go for more. cams i also agree with you i want some skunk2 pro 1s but it all comes down to how much cash i will have left and this will mostly be a street car but it wont always be at 600hp. the headgasket was bought from golden eagle with the block.
stock cams are better than those crowers. there is no need for a 900whp turbo on a 600whp build, look into something smaller. depending on your setup and how much torque you make the comp stage 5 might not hold, might want to look into a twin disk. dont forget to use a Golden eagle head gasket.
r u planning on street driving this on pump gas?? i def wouldnt try to go 600 on pump.. go for a high boost low boost setup, make yourself otherwise you will do nothing on the street but spin.. i went 553hp on the street and i only hooked in 4th.. but I agree with a recent comment, that turbo is waaay to big.. i got my 600 goal accomplished easily with a 6265sp precision.. and i have wayy more room up to from 650-750.. Are you streeting the car, tracking the car, running pump, or race gas?
sorry didnt see this post.. btw what size sleeves are you running?
gas will be pump 94octane Bore size is 81.5 and as for the turbo 600hp is not gunna be the end for me down the road i will always go for more just have to upgrade the clutch and fuel system to make more and it wont be at 600 every day i will be running off wastegate most of the time
oh sorry forgot to add but i already have a dualcore mishimoto rad
and as for why i want the power? i.v had a 300hp civic a 400hp civic and a 500hp civic i get bored very easy and like people aways say you will always want more
What they're trying to tell you is, shooting for 600 whp on pump gas is asking for trouble. Your tuner's margin for error is gonna be EXTREMELY minimal, not to mention, spinning 1st through 4th sucks on the street. Hope you got an LS tranny in that thing...
A 6765 will laugh at 600 whp, and will have a ski jump powerband for the street. If you still planning on running it and going for even more whp in the future, I suggest you throw race gas in this thing & run it at the drag strip, hence my sacrifice comment.
But it's your car, do you, homie.
bubblevic
Jan 28, 2008 11:54 AM
19sec beast
Feb 25, 2006 01:51 PM
