Wich turbine housing too chose !??!
Hi
I built out a B20C5 ( b20a block with itr head ) that will have a redline set at 7500 rpm and want a gt3076r as turbo. but i have to chose turbine housing a/r .63 or .82 and dont know witch is better
i need some help here
thx
Modified by woolfgang at 2:10 PM 2/23/2008
thx
Re: Wich turbine housing too chose !??! (woolfgang)
What are your goals for the car? What will you be doing with it? How much boost do you plan to run?
The .82 will have a little more lag but will ultimately make more power up top. But depending on what your doing, it may not even be necessary.
if your redline is set at 7500 you want the.63 it give you a better power band the .82 wont spool up till 52-5500 really no fun on the street if your going to get head work and up your rev to 85-9500 then i would go with with the .82. good luck
mrbsponge
04-12-2005 06:46 AM
