What makes the Rev-Hard not boost creep like the Drag manifold?
Look just like my Drag and people say even with a 3inch exhaust you won't see boost creep is this true? and will it work with a Drag downpipe? Cuz my Drag manifold is driving me crazy!!!
Re: What makes the Rev-Hard not boost creep like the Drag manifold? (9psiTurboSI)
Hey man the difference is the wastegate placement if u look at a DRAG and a REV-HARD the wastegate on the REV-HARD is more in the middle vs the DRAG is on the number one runner. REV-HARD is better mani in my views.
I have a rev hard on my car it stays at 9psi so fare and so does TURBODCX he is running i believe 15psi and no boost creep at all
If u look on this post u can see the difference in the wastegate placement.
https://honda-tech.com/zerothread?id=808342
Turbocx has a 3" and a revhard and not one prob with boost creep so u should be fine.
Re: What makes the Rev-Hard not boost creep like the Drag manifold? (JDMCRX)
That RevHard turbo manifold looks just like the InlinePro one, but then again they all look like someone else's these days... Just as long as they work is my only concern.
Re: What makes the Rev-Hard not boost creep like the Drag manifold? (TurboChrgd_Civic)
Just look and see what professional drag racers have used to get their cars into the 10's and 9's. Besides custom fabricated tubular manifolds, you will find that racers do/did use Inline Pro and Revhard manifolds (but no Drag manifolds).
Re: What makes the Rev-Hard not boost creep like the Drag manifold? (SiRex91)
I have a rev-hard as shown above and i never thought about it tell i read this post.. but i have never got any boost creep and im on 15psi everyday....
REV-HARD ... or not at all..
The DRAG is made for a cheap, reliable, a/c friendly, kit that can go on daily driven cars. It's not a all out race manifold which is why the pros don't use it.
I have run up to 10psi on my DRAG kit with even a Deltagate with no boost creep problems. I've ran open DP and exhaust, either way it stays where I set it. I am running a MBC is the only add on so i'm not sure why some people complain about creep and others have no problems at all.
Re: What makes the Rev-Hard not boost creep like the Drag manifold? (nsxmatt)
I dont get it either why some people have no issues and others do.
Where are you running your WG vacuum source to?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">The DRAG is made for a cheap, reliable, a/c friendly, kit that can go on daily driven cars. It's not a all out race manifold which is why the pros don't use it.
I have run up to 10psi on my DRAG kit with even a Deltagate with no boost creep problems. I've ran open DP and exhaust, either way it stays where I set it. I am running a MBC is the only add on so i'm not sure why some people complain about creep and others have no problems at all.</TD></TR></TABLE>
because we run 2.5inch downpipe to 3inch exhaust... that's what causes the creep!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboChrgd_Civic »</TD></TR><TR><TD CLASS="quote">That RevHard turbo manifold looks just like the InlinePro one, but then again they all look like someone else's these days... Just as long as they work is my only concern. </TD></TR></TABLE>
The inlinepro manifold looks just like the Revhard That Rev-hard manifold works great.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9psiTurboSI »</TD></TR><TR><TD CLASS="quote">
because we run 2.5inch downpipe to 3inch exhaust... that's what causes the creep!!!</TD></TR></TABLE>
Read mine again, i've run to exhuast and to open downpipe. Either way no creep. I'm also running my WG vac line to the turbine housing with the MBC in the middle.
I had a drag manifold that was cracked and welded back. One day it just tapped out. I bought my revhard and never had a problem yet
Wrong...I have a drag manifold with a t3/t04e and a 2.5"-3" dp and I have no creep at 10psi all day I don't know why people are having problems
I'm running my vaccum souce exactly the same
Read mine again, i've run to exhuast and to open downpipe. Either way no creep. I'm also running my WG vac line to the turbine housing with the MBC in the middle.</TD></TR></TABLE>
[QUOTE=nsxmatt]
I'm also running my WG vac line to the turbine housingQUOTE]
I should try that
I should try that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9psiTurboSI »</TD></TR><TR><TD CLASS="quote">[QUOTE=nsxmatt]
I should try that </TD></TR></TABLE>
Do it, and tell us your results. This isnt the first time someone has mentioned that switching their vacuum source may make a difference! Damn would it be nice if thats all it is.
I have gone as far as welding the factory wastegate placement on my Drag, and placing a new wastegate flange in the middle of all four runners to help eliminate it. Still getting creep, time for a new manifold.
Re: (GEN2TEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GEN2TEG »</TD></TR><TR><TD CLASS="quote">I have gone as far as welding the factory wastegate placement on my Drag, and placing a new wastegate flange in the middle of all four runners to help eliminate it. Still getting creep, time for a new manifold.</TD></TR></TABLE>
Where are you running your vac line?
*Boostwerks*
11-30-2002 12:58 AM
