Will this fuel combo work?
Old Dec 12, 2002 | 08:45 AM
rbf351's Avatar
Default Will this fuel combo work?
instead of using stock injectors, intank pump and FMU i was thinking of using
450cc DSM injectors and VAFC hack
would i still need the intank pump?
Old Dec 12, 2002 | 08:58 AM
VaporTrail's Avatar
New User
Default Re: Will this fuel combo work? (rbf351)
no, you would not. The purpose of getting the bigger pumps is to supply enough fuel at higher fuel pressures, which without a FMU you, you won't see ultra high fuel pressures. The stock pump is sufficient
Old Dec 12, 2002 | 09:05 AM
rbf351's Avatar
Default Re: Will this fuel combo work? (VaporTrail)
so i can basically throw out/sell my intank pump and FMU and have no problems?
Old Dec 12, 2002 | 09:07 AM
VaporTrail's Avatar
New User
you got it! Make sure you tune it with a wideband though
Old Dec 12, 2002 | 09:13 AM
rbf351's Avatar
i dont have a wideband
but was gonna just not run above 5-7 PSI till i get it tunned and hope that the autometer a/f gauge stays green a WOT
Old Dec 12, 2002 | 09:16 AM
VaporTrail's Avatar
New User
search around and find a dyno center in your area. http://www.dynojet.com is a great place to look. Many dyno centers have wide band o2's. A good safe setting is -37% all the way across. Definately be easy on it before you get it tuned though
Old Dec 12, 2002 | 09:25 AM
rbf351's Avatar
only one near me is
D R T Inc.
50-33 73rd Place
Woodside, 11377
Tel. 718-397-8586
and they aren't too cheap
as long as i know that the 450's and VAFC hack will work with nothing else i'm happy
Old Dec 12, 2002 | 09:26 AM
rbf351's Avatar
also shgould i leave the fuel pressure at the stock 35? or should i raise it up a little
Old Dec 12, 2002 | 10:40 AM
ekb18c's Avatar
Clayton dyno here!
civicdragger818
Jun 20, 2003 01:07 PM
B18C-RnVA
Dec 28, 2002 11:58 AM
pelotudo
Sep 14, 2002 12:35 PM
gsr sol
Aug 29, 2002 09:18 AM
2K1NBGSR
Feb 25, 2002 02:31 PM
