fuel question
Old Dec 28, 2002 | 10:23 AM
B18C-RnVA's Avatar
New User
Default fuel question
i have a built block, but i put on my turbo kit after breaking in my motor. so i went to my shop to put on an inline fuel pump. they told me to go with the intank walboro 255lph pump. so i did... running stock injectors and a 12:1 FMU disk.
now i drove the car hit about 5 lbs of boost and my autometer A/F guage went into the red. im wondering why am i running lean..according to the guage??
should i have just kept the FMU??
Old Dec 28, 2002 | 10:26 AM
boostaholic's Avatar
Default Re: fuel question (B18C-RnVA)
You need to run an inline fuel pump with the high rise rate FMU. The regular Walbro 255lph intank can't supply the needed fuel at high fuel pressures.
Old Dec 28, 2002 | 10:36 AM
LJR-LUDE01's Avatar
Default Re: fuel question (boostaholic)
I tough just running the 255lph intank pump would supply enough fuel to support this... would the inline fuel pump still be needed if i use 450 DSM injectors instead of my stock? sorry to jump on you question tony
[Modified by LJR-LUDE01, 7:39 PM 12/28/2002]
Old Dec 28, 2002 | 10:53 AM
B18C-RnVA's Avatar
New User
Default Re: fuel question (LJR-LUDE01)
well dam, i just wasted my money then, i shouldve waited for the intank and just got the inline installed...
Old Dec 28, 2002 | 10:57 AM
BudaKai's Avatar
Actually you should have just gone standalone... Otherwise why did you build it?
Old Dec 28, 2002 | 11:30 AM
B18C-RnVA's Avatar
New User
Default Re: fuel question (tzsir)
standalone is comming at the end of january, when i get more moeny....i just wanted to run a nice little 6-7psi..thats all
Old Dec 28, 2002 | 11:50 AM
b16ahybrid's Avatar
yeah in that case you did waste your money....
If you were to get a pump the one you should have gotten was the 255lph high pressure intank fuel pump.Walbro/holley makes one.
Now that you have the high flow pup it will work great for when you get the stand alone and larger injectors...
Old Dec 28, 2002 | 11:58 AM
speedy108's Avatar
Default Re: fuel question (b16ahybrid)
From what Arturbo told me a long time ago when I was just doing a basic DRAG setup on my GSR, 12:1 FMU, Inline pump, STOCK in-tank pump. And no more than 6-7psi.
Another thing he told me was K.I.S.S (Keep It Simple Stupid)
But regardless of a stock motor or built, I wouldn't put a turbo kit on my car until I had a standalone. Ask anyone on this board and I think most would agree.
rusteds2k
Jan 29, 2004 06:52 AM
civicdragger818
Jun 20, 2003 01:07 PM
PUREVIL
May 8, 2003 06:55 PM
2K1NBGSR
Feb 25, 2002 02:31 PM
5gen-hybrid
Aug 5, 2001 10:17 AM
