wich nipple on the tial 35mm wg??????
Re: wich nipple on the tial 35mm wg?????? (babyboib16)
Top is for boost controller whether manual or electronic
Side/Bottom is vacuum.
theres 2 ways to do this.
1. IF USING A BOOST CONTROLLER: hook the side port to the turbo outlet and the boost guauge to the MANIFOLD so you can adjust the boost.
2. If NOT using a boost controller, hook the side port to a MANIFOLD source.
Re: wich nipple on the tial 35mm wg?????? (Foozball26)
some one told me to hook my boost guage to the fpr hose. and run the side nipple on the tial wg to the turbo. i dont have my boost controller yet but will have one in a month or 2. does this sound right?
You will want a vac/boost (intake manifold) source. Something after the throttle body. You could tee into the brake booster source or tap strait from the intake manifold. I would not use the fpr line, it would be alittle small for the WG.
Taking the signal from the turbo compressor will not show the pressure drop across the intercooler and charge piping
Re: wich nipple on the tial 35mm wg?????? (BROOD)
i am running the boost guage to the fpr line not the wg is that right? also what would be the best vac source for the wg? where on the intake mani?
Silva Bullit DC4
01-17-2008 02:06 PM
