why 2 bov's?
Old Jun 22, 2003 | 01:16 PM
B00STeD's Avatar
Default why 2 bov's?
I went to a cra show this weekend in Miami, Fl and saw multiple cars running 2 blow off valves right next to eachother. What good is this/???
Old Jun 22, 2003 | 01:23 PM
Adriano's Avatar
Default Re: why 2 bov's? (B00STeD)
Maybe they where running really high lbs. Dont tell you saw a guy boosting 5lbs with 2 bov.
Old Jun 22, 2003 | 01:33 PM
swlabhot's Avatar
Addition relieve for high boost apps..
Old Jun 22, 2003 | 03:25 PM
civperc's Avatar
Default Re: why 2 bov's? (swlabhot)
did you see this on Hondas?
Old Jun 22, 2003 | 03:38 PM
hondaspeder's Avatar
so if i use 8 pounds of boost on the street and 20 at the track i could use 2 bovs and tune one for street and one for track correct.... thanks
Old Jun 22, 2003 | 04:15 PM
Adriano's Avatar
Default Re: (hondaspeder)
It doesn;t work like that. Put it this way, if you get a hole in you tire, the air will come out. If you have 2 holes, more air will come out. Same thing with 2 bov, it will relieve more air. Get it?? That's why only high boost (like 30+ lbs) would need it
Old Jun 22, 2003 | 05:11 PM
B00STeD's Avatar
Default Re: (brryder)
I saw it on an eclipse and on a new celica.
Old Jun 22, 2003 | 06:49 PM
say u had adjustable ones like greddy and u turned one i guess to hard and one to soft would it work
Old Jun 22, 2003 | 06:51 PM
90teg's Avatar
only high boost like 30+.......that would be a car you won't drive on the street. would you need 2 if you boosting 20+?
Old Jun 22, 2003 | 06:59 PM
GraphiteAccord's Avatar
Default Re: (90teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90teg &raquo;</TD></TR><TR><TD CLASS="quote">only high boost like 30+.......that would be a car you won't drive on the street. would you need 2 if you boosting 20+?</TD></TR></TABLE>
this is big on supras, they run huge turbos that move a lot of volume and high boost. the two are needed no doubt...
Old Jun 22, 2003 | 07:16 PM
90teg's Avatar
Default Re: (GraphiteAccord)
have you seen any street honda's with them?
Old Jun 22, 2003 | 08:55 PM
Agamemnon's Avatar
New User
Default Re: (90teg)
I saw a pic of a b16 with two HKS ssq's. Id say more show than anything...
Old Jun 22, 2003 | 11:10 PM
one more chance's Avatar
running one high boost BOV is still more efficient that having two smaller boost BOVs. i think the twin BOVs is more for show pony cars.
Old Jun 23, 2003 | 02:16 AM
lazerus's Avatar
Default Re: why 2 bov's? (one more chance)
if you are making a good deal of power, and when you shift blow intercooler pipes off, two blow off valves would work, or one larger valve. I would assume people would use twin hks valves mainly for the noise, and also for the function.
Brad
swappedcx
Aug 13, 2007 04:24 PM
wade
Nov 6, 2006 09:46 AM
JMcDB18C
Apr 27, 2005 02:37 AM
JGurr81
Dec 9, 2003 10:27 AM
LshatchTurbo
Apr 5, 2003 07:51 AM
