Does cold weather cause creep?
Old Nov 5, 2006 | 07:01 PM
wade's Avatar
Default Does cold weather cause creep?
Maybe I am just smoking crack, lol, but it seems when the weather drops below 40-35 degrees my boost starts to creep some at night time. During the day, when its warm it holds fine...
Old Nov 5, 2006 | 07:19 PM
Boilermaker1's Avatar
Tagging along, I'm experiencing the same phenomenon.
Old Nov 5, 2006 | 07:58 PM
krazyhmongboi's Avatar
not shure if its creep..but when its real cold outside..my bov is softer till i give it a good kick of boost then after that the bov sounds normal..guess it warms it up
Old Nov 5, 2006 | 08:07 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (krazyhmongboi)
cold weather = boost creep
Old Nov 5, 2006 | 11:35 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
^^^is that true?
Old Nov 5, 2006 | 11:38 PM
HNLV's Avatar
i heard from some poeple that they experienced it during the winter time. But im not sure if it is true or not.
Old Nov 6, 2006 | 12:01 AM
B18C1CYA's Avatar
Default Re: (sqeezincheeser)
Cold weather = creep do to the air being more dense so there is more to compress
Old Nov 6, 2006 | 03:07 AM
VtecnTurbo's Avatar
Default Re: (B18C1CYA)
how do you adjust ? re tune ? turn down the boost a few pounds during the winter season?
Old Nov 6, 2006 | 03:42 AM
wade's Avatar
Default Re: (VtecnTurbo)
i actually turned my boost UP , thus, makes the WG have to expell less exhaust gas and can control the higher level more accurately.
Old Nov 6, 2006 | 06:52 AM
adseguy's Avatar
Default Re: (wade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wade &raquo;</TD></TR><TR><TD CLASS="quote">i actually turned my boost UP , thus, makes the WG have to expell less exhaust gas and can control the higher level more accurately.</TD></TR></TABLE>
I was thinking about this, but here's the problem. If you make more power you need more fuel thuis more air thus more exhaust....so I think you may be wrong about that haha. I know you will need more exhaust gas to create more boost, but I think once you reach full boost you'll have more exhaust gas to expell anyway.
To the OP: Cold winters seems to mess with the wastegate since temperatures vary the toughness of the WG spring. Either turn down the boost so the max boost creep is where you are tuned at, or just deal with it.
Old Nov 6, 2006 | 09:30 AM
CRXdan's Avatar
Default Re: (adseguy)
only noticed this with small turbos.
Old Nov 6, 2006 | 09:37 AM
wade's Avatar
adse, sorry man... My car is tuned for higher levels, so i can turn it up if i please. I didnt pay 2,200 for an autronic to put to good use for nothing. And yes, my car does hold boost better at higher boost levels, so thanks again
Old Nov 6, 2006 | 09:46 AM
seen4ever's Avatar
Default Re: (wade)
it also depends on the boost controller you run. aka if you are running off the gate, it shouldn't matter, as pressure is pressure. if you are running a EBC, you may need to adjust the duty cycle if its hard coded, i know my AVCR adjusts automatically due to the fuzzy logic, but I believe with AEM/Autronic, etc you set a duty cycle, which may need to be adjusted.
Also for Manual boost controllers, you will have to adjust them, as the difference in the air mass, changes with temp.
97grnrs
Jul 28, 2008 03:50 AM
wade
Dec 4, 2006 01:49 PM
RTW DC2R
Nov 17, 2006 03:19 PM
93civciv
Feb 3, 2006 10:21 PM
trbob16a
Nov 18, 2003 04:55 PM
