Which BOV to run.....
Old Apr 26, 2005 | 04:53 AM
JMcDB18C's Avatar
Default Which BOV to run.....
Well, I dont really know to much about BOV's but Everyone tells me for high boost and high hp, the tial seems to be the choice to go with, now, i really like the greddy type r and the HKS, are those capable of handling high boost....?? All info greatly appreciated.. Thanks
Jon
Old Apr 26, 2005 | 06:06 AM
Nytmair's Avatar
how high of boost? if somewhere around 10-15 or so (i know that's not that high...) try for a DSM 1g BOV, they're only like $40, maybe cheaper if you look enough. that's my plan. Also, they can be modded to hold more psi is you need to.
Or, tial is a real good BOV too if you need higher than that.
Just my 2 cents
Old Apr 26, 2005 | 06:28 AM
HamiltonRex's Avatar
Default Re: (Nytmair)
What about just a simple 7-9psi setup.. I would like to use Tial? But are they only recommended for high boost.. Or can they be used with low boost setups as well?
Old Apr 26, 2005 | 06:29 AM
underpressure02's Avatar
Default Re: Which BOV to run..... (JMcDB18C)
like the other guy said how much boost are you planning on running?
Old Apr 26, 2005 | 06:41 AM
brickonwheels's Avatar
I use a tial on my 8psi set up and couldn't be happier.
Old Apr 26, 2005 | 06:44 AM
RemerLex11's Avatar
Default Re: (brickonwheels)
if you're not running high boost a friend of mine uses a cheap *** one off ebay and it works great
Old Apr 26, 2005 | 07:02 AM
PrettyLude's Avatar
hks super sequential
Old Apr 26, 2005 | 08:17 AM
Wideopentuning's Avatar
Default Re: (PrettyLude)
I ran 3.5psi for a bit and my Tial valve acted fine.
Old Apr 26, 2005 | 09:13 AM
White Smoke's Avatar
i my honda
Global Mod
Tial will work fine for low and high boost.
The Greddy type R is made for major boost, up to 30psi or so.
The HKS is good to at least 20psi. I have heard of small flange leaks from them before due to the 2bolt design but there normally fixable.
Tial is just what everyone has, be smart, be different
Old Apr 26, 2005 | 04:40 PM
JMcDB18C's Avatar
I will be running 15-18 pounds on the street and 27-30 @ track looking to dyno around 650whp, so....im probably gonna go with tial, ive heard notthing but good things, thanks all you guys for response....
Old Apr 26, 2005 | 06:12 PM
dustin's Avatar
tial is a great BOV. You will be happy with it
Old Apr 26, 2005 | 06:22 PM
BoostedCivicSedan's Avatar
Default Re: Which BOV to run..... (dustin)
My Tial has seen anything from 9psi, to 35psi (on average 17-20psi), and has never given me any real problems... I originally purchased it with the 11 psi spring, and it surged alot at lower boost... I switched it to the 7 psi spring, and it works great, and does exactly what it should....
Old Apr 26, 2005 | 06:27 PM
Blow off valves, not wastegates.
Old Apr 27, 2005 | 12:57 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brickonwheels &raquo;</TD></TR><TR><TD CLASS="quote">Blow off valves, not wastegates.</TD></TR></TABLE>
Exactly what I was talking about... Read my post again where I said it surged with the 11psi spring... Wastegates dont cause compressor surge
Just to further clarify, Tial blow off valves have different spring options... 7psi, 9psi, and 11psi....
Old Apr 27, 2005 | 02:37 AM
H.A.R.T B18C1EG6's Avatar
Default Re: (BoostedCivicSedan)
RFL is nice and cheap
GSROWNSU
Apr 11, 2007 04:31 PM
N20civicB18
Jul 6, 2005 07:48 PM
DamonBoost
Jun 4, 2003 08:36 PM
eg2turbo
Dec 9, 2002 09:51 AM
