White smoke in #1 cyl while engine breaking.
Old May 25, 2006 | 07:31 PM
nota-eg's Avatar
Default White smoke in #1 cyl while engine breaking.
I have a D16Z6 and if I drive the car WOT it starts to smoke around 4500 or as I'm engine break downhill. I know it's water from the coolant system.
I pulled the plugs after driving one day and white smoke was slowly coming out of cylinder #1.
My AFRs are around 13.5 in VAC and 12.5 in boost. Running 12lbs on a TD04 14G turbo. I just ordered a new dizzy because I have a random misfire at idle and the car will not go above 5k on occasion
I blew the headgasket over 6 months ago and installed ARPs when I replaced it. I did not have the block/head leveled.
Is there a chance the head/block is warped, the HG is blown, or could it be a cracked cylinder?
I don't want to pull the head to see if the cylinder is cracked because I don't want it to shift if I pull teh head and I don't want to blow $60 on a headgasket for a motor I'm about to pull anyway.
I'm just currious as to what you guys think could be the problem.
Thanks
-Nick
Old May 26, 2006 | 12:04 PM
nota-eg's Avatar
Default Re: White smoke in #1 cyl while engine breaking. (nota-eg)
Bump.
Old May 26, 2006 | 08:51 PM
jdm-ray's Avatar
From: home of Marciano/Haggler, city of champions, MA
your rings on #1 are shot. or maybe the valves. does it drive the same?
Old May 27, 2006 | 11:19 AM
nota-eg's Avatar
Default Re: (h22boy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22boy &raquo;</TD></TR><TR><TD CLASS="quote">your rings on #1 are shot. or maybe the valves. does it drive the same?</TD></TR></TABLE>
No, it doesn't. I have a cylinder misfire and recently (last 2 weeks) I can't really take the car over 5k.
I was thinking it's the distributor causing that, so I got a new one (about to go put it on as I'm typing this).
Other than the mis at idle and it not going above 5k it's still relatively strong.
I never would have thought the rings would cause it to smoke white because white smoke means coolant/water.
Thanks for your input.
-Nick
Old May 27, 2006 | 11:32 AM
BLKTeg94's Avatar
Do a leak Down test before you start taking it apart. that'll tell you exactly what's wrong.
Old May 27, 2006 | 10:05 PM
nota-eg's Avatar
Default Re: (BLKTeg94)
I'm going to do a leakdown test tomorrow.
I know this is ghetto/band-aiding a problem, but I was thinking that if it turns out to be the rings I could always just swap a stock piston with rings from my spare motor into the #1 cylinder.
That way I'm only paying $50/60 for a new headgasket vs 150 for rings & a headgasket on a motor that only has to last me another month, two tops.
Old May 28, 2006 | 10:06 AM
jdm-ray's Avatar
does your exhaust make a different sound. kind of sounds like a bumble bee, or that wrx sound? no dead serious that happened in my friends gsr when he blew his rings and snapped his belt. plus it drove like a slug
Old May 28, 2006 | 11:04 AM
nota-eg's Avatar
No, exhaust and everything else still sound the same.
With the new dizzy I can take the car above 5k (took it to 6k and then shifted just to see if I could.) Dizzy fixed that problem.
I'm going to try to get a leakdown test done tomorrow. If it turns out to be the #1 cyl rings I may switch the piston like I mentioned earlier. Just don't really want to spend the time pulling the head and pan just to throw in a piston.
derek18105
11
Nov 25, 2012 04:19 PM
tony_yang
May 13, 2010 07:18 AM
boostedjdmdc2
Mar 10, 2009 09:22 PM
curtiss_robinson
Jan 11, 2009 06:46 PM
Mjh787
18
Jun 14, 2006 07:01 AM
