Turbo oil inlet is not threaded??
Hey there are no threads on the inside of the turbos oil inlet. I though there should be. Or does something else attach there?
Thanks for the help
Thanks for the help
Re: Turbo oil inlet is not threaded?? (Gdub00lude)
non-ball bearing center housings usually need an inlet flange. typically ball bearing center housings are the only ones with threaded oil inlets.
edit: this info is wrong, and I made this **** up
Modified by Stop the Beast at 10:02 AM 2/8/2006
Re: Turbo oil inlet is not threaded?? (Stop the Beast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stop the Beast »</TD></TR><TR><TD CLASS="quote">non-ball bearing center housings usually need an inlet flange. typically ball bearing center housings are the only ones with threaded oil inlets.</TD></TR></TABLE>
just curious, is there a way to tell if you have a ball bearing housing? my t3 has threaded oil feed, i just always thought the more expensive turbos only had ball bearing center housings........
Re: Turbo oil inlet is not threaded?? (thelate1)
when I got my garrett 60-1 turbo a while back it was the same way "no threads"
me and my buddies went to lowes and got a tap. Now it has threads
90% of the journal bearing turbos out there are threaded. its not just ball bearing turbos.
Re: Turbo oil inlet is not threaded?? (CoreyR)
are you kidding? why make up **** if you dont know the right anwser?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoreyR »</TD></TR><TR><TD CLASS="quote">
90% of the journal bearing turbos out there are threaded. its not just ball bearing turbos.</TD></TR></TABLE>
exactly, its probably more like 99%
Re: Turbo oil inlet is not threaded?? (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch »</TD></TR><TR><TD CLASS="quote">
exactly, its probably more like 99%</TD></TR></TABLE>
Yeah, I totally made that up sorry. Nope I just didn't ever pay attention to the threads until now, whoops. I always used an inlet flange to elminate the need for a threaded fitting directly into the turbo. Don't accuse me of making up ****. I was wrong but I didn't make up ****.
Very Emergency!!
my roomates t-3 is the same way. just go to full-race.com or phoenixturbo.com and get the oil feed flange and gasket. this will allow you to get a threaded fitting in there. hope that helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stop the Beast »</TD></TR><TR><TD CLASS="quote">Yeah, I totally made that up sorry. Nope I just didn't ever pay attention to the threads until now, whoops. I always used an inlet flange to elminate the need for a threaded fitting directly into the turbo. Don't accuse me of making up ****. I was wrong but I didn't make up ****.</TD></TR></TABLE>
so instead of using a fitting that costs $3 you spend $15 on a oil inlet flange? sounds kinda like a waste of money to me
Thanks guys, even though you went totally off the topic, and only two of you actually answered my question.
Yeah, I totally made that up sorry. Nope I just didn't ever pay attention to the threads until now, whoops. I always used an inlet flange to eliminate the need for a threaded fitting directly into the turbo. Don't accuse me of making up ****. I was wrong but I didn't make up ****.</TD></TR></TABLE>
You wrote 2 sentences. Neither of them are technically correct and you presented them as fact, therefore you made them up.
Before I type something I am fully aware of whether or not I know it as a fact, or if it is opinion or speculation. I then phrase my response as such to avoid being forced to argue semantics with some bored ******* on the intraweb. It works out really well since I dont know everything, but wish to express my opinion publicly.
good luck with that turbo.. i just got an xs kit and the turbo smoked from day one.. im in the precess of gettiing them to replace it. ..
Clearly you are master of rhetoric, and a technically astute character, and I was a fool to state inaccurate claims in your presence. Perhaps, in the future I will tread more carefully in threads that you’ve partaken in.
Truly Sorry,
Stop the Beast
Truly Sorry,
Stop the Beast
deadhero15
05-23-2017 02:53 AM
Vagitarian
12-24-2012 04:12 PM
LOGONZOJLS
09-01-2006 09:08 AM
