where do i buy check valves for map sensor?
i was told to use 1 check valve for every 5lbs. of boost i run. what kind of check valves are they and where can i buy them? if anybody can help let me know. thanks.,
Re: where do i buy check valves for map sensor? (mracura)
walmart. The best store on earth has everything you need. Go to the fish tank section of your local super wallmart which is taking over the world... but anyways go there and your should get fish tank check valve.
should cost 1.99
should cost 1.99
Re: where do i buy check valves for map sensor? (b18bturbo)
make sure you install them correctly. the side you cannot suck through goes towards the engine. the other end is left open
pep boys, track auto, napa, autozone,pets mart, any local aquarium store......and so on................................................ .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. ........
