check valve
Old Jun 9, 2003 | 08:27 PM
wanttorace's Avatar
Default check valve
what will happen if i dont have one will it run like **** becuase the map sensor?
Old Jun 9, 2003 | 08:47 PM
b16ahybrid's Avatar
Default Re: check valve (jjd493925)
map sensor will throw a code and you will run in limp mode.....shitty......
Old Jun 10, 2003 | 07:26 AM
wanttorace's Avatar
Default Re: check valve (b16ahybrid)
even on like a 6 pound spring?
Old Jun 10, 2003 | 07:35 AM
ELSpool's Avatar
Yep, as soon as the MAP reads positive pressure around a lbs of boost, it will shut the fuel/ignition down. Run a few check valves inline, I used to run 6 on my other car.
Old Jun 10, 2003 | 08:28 AM
wanttorace's Avatar
Default Re: (ELSpool)
so where do i get the check valves from if anyone has some part numbers that would be great caz right when i hit boost it peeks to 6 or 7 then it starts to sputter around 4 or 5 grand
Old Jun 10, 2003 | 08:43 AM
B18PoweredCivic's Avatar
Default Re: (jjd493925)
you can get the check valves at any pet store or store that sells aquarium accessories...There about 1 dollar a piece..Just got to any pet store and ask them..They'll know what your talking about...There used on fish tanks...
Old Jun 10, 2003 | 08:23 PM
wanttorace's Avatar
Default Re: (B18PoweredCivic)
then how do you hook them up on a 94 integra
Old Jun 11, 2003 | 06:24 AM
http://www.cse.uconn.edu/~yele....html .....Check there...Scroll Down till you see the instructions for Chech Valves
Old Jun 11, 2003 | 06:55 AM
turbochic's Avatar
if you can afford it get a missing link, the check valves work but it looks kinda crappy, i still have my check valves on my car, and cant wait to get a missing link, i had to run 3, on my car. its so easy to hook up you should have no problems.
as for the guys at pet stores knowing what your talking about, i called three big pet stores and they were like" huh check valve? is that a pump?" so i just had to go and look myself.
93hondaboy
Jan 27, 2005 02:59 PM
Pengo
Jul 30, 2002 08:43 PM
turbotec
Feb 26, 2002 03:34 PM
Teluan
Sep 3, 2001 07:29 PM
