Whats a good fuel setup with hondata?
New User
OK I have a 95 gsr. Im planning on boosting about 15-18 lbs at the track. What would be a good fuel setup that would provide enough fuel with a hondata ecu.
I was thinking
RC 550 injector (are these to big or should i get 440)
Aem fuel rail and pressure regulator
Bosch fuel pump (whats better intank fuel pump or external)
I was thinking
Re: Whats a good fuel setup with hondata? (Trajic)
You are gonna lean out at 18psi with the 550cc injectors. Go larger if you really want 18psi, else stick to 15-16psi. This depends on your static fuel pressure but 50-60psi static is good.
Dustin
Dustin
New User
Do u think with a T3/to4 e turbo and hondata at 15lbs I can male enough power to hit 11's
New User
I hope you are lowering the compression or somehow strengthening the bottom end running that much boost.
11s depends on driver and traction...it could happen
New User
I have the fuel pump that came with my drag III kit, aem fuel rail, aem fuel pressure regulator, eagle rods, je 9.5-1 pistons, and block guard and am hoping to boost 17 at the track.. i am gonna run 550s as well.. and hondata stage 3b. hoping to break into the 11's
Brian_92GSR
10-25-2001 11:27 AM
