Stand Alone Fuel Management
Old Dec 28, 2001 | 09:05 AM
thequickest GS-R's Avatar
Default Stand Alone Fuel Management
For learning's sake, let's say that somebody has a '98 Civic EX and this person wants to run an insane amount of boost, and has enough money to invest in a stand alone fuel management system. Here's the question, what all would he need? Thanks for all your help.
Ben
Old Dec 28, 2001 | 09:09 AM
Spade's Avatar
Default Re: Stand Alone Fuel Management (thequickest GS-R)
High volume fuel pump, fuel regulator, injectors, and a fuel management system/ecu like hondata. How much boost? Looking at plus 300 horses? then a fuel rail is required and a high flow filter as well.
Edit: Did I miss anything?
[Modified by Spade, 10:09 AM 12/28/2001]
Old Dec 28, 2001 | 10:20 AM
Default Re: Stand Alone Fuel Management (Spade)
I haven't heard that much about hondata, what exactly is it, and does it actually work. The situation was hypothetical, but yeah, 300 fwhp is about right. What do you think about AEM fuel delivery equiptment (i.e. rail, regulator, pump)? Thanks.
Ben
Old Dec 28, 2001 | 10:22 AM
Spade's Avatar
AEM, STR, Venom, whoever, all that equipment is just tubes
http://www.hondata.com programmable ecu best on the market for a honda.
Old Dec 28, 2001 | 10:32 AM
rainforest's Avatar
yes i like sds or hondata the oly diff between the 2 is sds has the acessiblity to be able to change at any moment from inside the car. the hondata uses a dataloger so you can get your runs dataloged and then see how you ran and then change it from that.
Old Dec 28, 2001 | 10:33 AM
Spade's Avatar
Default Re: Stand Alone Fuel Management (rainforest)
hondata also allows an option for in car modifying but that is only avaliable on the stage 4 with another 270 bucks on top of what you are paying.
Old Dec 28, 2001 | 10:45 AM
Interesting...
Ben
Old Dec 28, 2001 | 01:02 PM
Short_Shifter's Avatar
What is SDS ?
I never heard of them !
Do they have a web site ?
Old Dec 29, 2001 | 01:36 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: Stand Alone Fuel Management (Short_Shifter)
SDS is Simple Digital Solutions. ( I think)
I can't remember the web site sorry.
Old Dec 29, 2001 | 02:36 AM
TurboMiata's Avatar
Default Re: Stand Alone Fuel Management (B18C-EJ1)
SDS doesnt have datalogging capability IIRC. you WANT datalogging capabilty. trust me....
Old Dec 29, 2001 | 02:44 AM
sgT's Avatar
sgT
Hondata works great.
Right now we are making over 375whp on 17psi with a "small" 50 trim t4e/t3 turbo.
This is a B18C ITR motor.
The only real downside to hondata is the lack of realtime program changes, but
realistically it almost never needs to be done. Most of the tuning I do is at the
track or the dyno. In those situations I have an emulator hooked up or I just make
minute changes and burn a new chip and make another pass.
Old Dec 29, 2001 | 09:38 AM
TurboSedan's Avatar
New User
Default Re: Stand Alone Fuel Management (sgT)
Hondata iz off da heeezy! LOL I always wanted to say that!
evade this honda
May 3, 2004 07:59 PM
Jared
May 26, 2003 09:29 AM
hatchback
May 20, 2003 09:00 PM
92intb18a
May 28, 2002 08:11 AM
