whats a good efficiency range???
Old Feb 5, 2004 | 09:45 PM
blackeg's Avatar
Default whats a good efficiency range???
ok i was doin some calculations and whatnot and i came up with this question- whats a good efficeincy for a turbo to run at? i was specifically lookin at t3 50 trim maps for use on my d16z6, and at like 7 psi(which is about what i wanna start at) it would be at around 70% efficient. is this too low??? turbo newb here just tryin to gain some general knowledge about this...
Old Feb 5, 2004 | 09:50 PM
Johnyquest's Avatar
Default Re: whats a good efficiency range??? (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">ok i was doin some calculations and whatnot and i came up with this question- whats a good efficeincy for a turbo to run at? i was specifically lookin at t3 50 trim maps for use on my d16z6, and at like 7 psi(which is about what i wanna start at) it would be at around 70% efficient. is this too low??? turbo newb here just tryin to gain some general knowledge about this...</TD></TR></TABLE>
Well, 70% at what RPM? Your never going to be in the turbo's full eff. range for too long. It's not a good way to plot on a map. You have to see how the entire operating range of the engine fits the map. You are only pointing out one point on the map. I know from experience that the 50 trim t3 is a good turbo on a D series, though. You want a .48AR hotside, and you'll love it. That's about as big as you'd want to go, actually.
Good luck.
Old Feb 5, 2004 | 11:56 PM
TravSi's Avatar
Default Re: whats a good efficiency range??? (Johnyquest)
d16 go t3 60 or super 60 , I have had so much great success with the 60 trim and the power is strong, I just plain love it ...Dont get the 50 trim, I was gonna get that but glad I didnt, go with the 60 trim, just all around great turbo for the d16...look at my numbers with 6psi and new numbers are comin soon @ 10psi
Old Feb 6, 2004 | 06:07 AM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnyquest &raquo;</TD></TR><TR><TD CLASS="quote">
Good luck.</TD></TR></TABLE>
i did plots for 3,5,7000rpm- put it between 70 and like 75% if i remember correctly, but then again this is like 7psi. eventually id be goin up to 10 or so...
Old Feb 7, 2004 | 02:58 PM
blackeg's Avatar
bump
Old Feb 7, 2004 | 04:29 PM
grndcont's Avatar
try to keep it above 60% for most of your engins cfm range (70-80% is real good). also, try to keep the compressors rpm below 100k.
Old Feb 8, 2004 | 06:39 AM
blackeg's Avatar
Default Re: (grndcont)
so then shoot for between 60 and 80%?
Old Feb 8, 2004 | 07:15 PM
grndcont's Avatar
i've never seen map that goes above like 78%, but ya, 60 or better for the meat of your cfm range is about where you want it. the higher the better of course.
blks2k3
Jul 24, 2006 11:01 AM
nota-eg
Oct 15, 2005 02:59 PM
killablaze
Oct 14, 2005 12:44 PM
Spoon98Hatch
Oct 19, 2004 10:10 PM
racinskittle
May 12, 2003 11:18 AM
